Old 03-18-2013, 04:54 PM   #1
JointTech
JointTech's Avatar
Universal sending unit
I have a saddletank that has a sending unit on it. When I got the truck there was a valve in the cab to switch between main and aux tank but there was no additional fuel gauge and the dash gauge obviously was connected to the main sending unit.
So I pulled the saddle tank out to have it cleaned and sealed so I can use it in place of the behind the seat firebomb.
when I took it in the guy said ill need a new sending unit. its pretty crusty.
Can I get just any universal unit or do a need a certain ohms to make it work with the factory fuel gauge?
The sending unit has the same retaining clip setup as the normal tanks. Is that part "keepable" and the universals connect inside to it? Or do I have to find a universal with the same locking nut dohickey on it?
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 03-25-2013, 06:33 PM   #2
JointTech
JointTech's Avatar
Re: Universal sending unit
Got my aux tank cleaned and sealed and he went ahead and cleaned and painted the outside for me!!
So now to find a sending unit / fuel pickup combo unit.
Has anybody ever seen a universal?
72 C20 Long Bed
Old 03-25-2013, 06:38 PM   #3
john
member #16
john's Avatar
I believe they are 90 ohm senders.
john is offline   Reply With Quote
Old 03-25-2013, 06:40 PM   #4
JointTech
JointTech's Avatar
I found this. It looks the same but mine uses screws to hold it in the tank and this one has a lock ring like the OE tanks. wonder if I can just screw it in.
doh forgot the link
http://www.summitracing.com/parts/gm...del/c10-pickup
72 C20 Long Bed
Old 03-25-2013, 06:51 PM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Stewart Warner 90 ohm sender should work, they screw down, just check dia.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 03-25-2013, 06:55 PM   #6
JointTech
JointTech's Avatar
ill check on those. thanks
72 C20 Long Bed
Old 03-25-2013, 06:58 PM   #7
JointTech
JointTech's Avatar
http://www.partdeal.com/gauges/sende...-90-ohm-1.html
found that but it doesnt have the pickup tube. Ill keep digging.
72 C20 Long Bed
Old 03-25-2013, 07:40 PM   #8
Ol Blue K20
HMM.... my aux tank doesn't pick up from the sender hole. I'm sure they make one though check Summit
Dale
Old 03-25-2013, 07:48 PM   #9
JointTech
JointTech's Avatar
im wondering if I can get a universal and use a bulkhead fitting for the pickup tube. Just drill an extra hole in the top of the sending unit plate and rig up some tube.
or maybe ill keep looking haha
72 C20 Long Bed
Old 03-25-2013, 07:52 PM   #10
Ol Blue K20
I wonder if yours is the factory/dealer installed unit. Mine are aftermarket
Dale
Old 03-25-2013, 07:54 PM   #11
JointTech
JointTech's Avatar
interesting. I was told aux tanks are all dealer or aftermarket.
72 C20 Long Bed
Old 03-25-2013, 08:00 PM   #12
JointTech
JointTech's Avatar
hey hey. found this. http://67-72chevytrucks.com/vboard/s...d.php?t=363854
wish I had my spid but it mentions the tank switcher beside the seatbelt which is where I had mine. And i have a hole in my dash which i now think is for the switch to change between sending units.
now that is cool.. 2 tanks using the same gauge.
So now I know(think) its a factory tank.
maybe I can find the sender/pickup.
thanks for pointing me there.
72 C20 Long Bed
Old 03-25-2013, 08:07 PM   #13
Ol Blue K20
No problem, you should look up under the dash and see if the switch harness is still there. I know the switches pop up in the parts board now and then. I don't know if the switches are still made or repoped
Dale
Old 03-25-2013, 09:45 PM   #14
SS Tim
SS Tim's Avatar
There were factory installed aux tanks. Either a behind the axle N18 or a driver's side forward under bed NL2. These would be on your SPID. Aftermarket and dealer sold/installed tanks are more often found with through bedside filler doors or wheel well fillers.
Here are a couple of pictures to get you started.
The entire NL2 tank installation is covered in the assembly manual.
The sender picture is the factory NL2 aux tank sender and it is application specific.
We also hashed a lot out on a WTB thread of Jockos that is worth reading through.
http://67-72chevytrucks.com/vboard/s...d.php?t=560607
SS Tim is offline   Reply With Quote
Old 03-25-2013, 09:52 PM   #15
JointTech
JointTech's Avatar
so i need a AC 6428850. mine is jsut like the blue truck and the service manual looks just like my tank in the pic above. !!
thanks.
now google comes up with nothing on a 6428850. but i have some place to start at least.
72 C20 Long Bed
Old 03-25-2013, 10:10 PM   #16
SS Tim
SS Tim's Avatar
IIRC livrat found that one on ebay and it is not for sale.
Old 03-25-2013, 10:14 PM   #17
SS Tim
SS Tim's Avatar
Most aux tanks are saddle tanks like these. This is a Demco wheel well filler kit ad from the Silverbook.
Old 03-25-2013, 10:15 PM   #18
JointTech
JointTech's Avatar
ok ill keep looking for something universal I can adapt. not trying to be correct, just want it to work.
72 C20 Long Bed
Old 03-25-2013, 11:19 PM   #19
JointTech
JointTech's Avatar
ah. they couldnt have made it so easy that its the same sending unit as the 67-71 Blazer/suburban? Looks dang close to mine and would have the right ohms.
I also see that 60-66 trucks seem to use the same style but would be only 30 ohm.
http://www.ebay.com/itm/54-55-56-57-...9d8309&vxp=mtr
http://www.brotherstrucks.com/prodin...number=GTS6972
http://www.classicparts.com/1967-72-...tinfo/23-534/#
72 C20 Long Bed
Old 01-21-2014, 02:05 PM   #20
MARKDTN
OP may have solved his problem, but Isspro makes a good quality aftermarket sender.
http://isspro.mybigcommerce.com/fuel-level-senders/
you can search around and find what you need. I have bought at least 2 for boats through them.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
