Old 03-18-2013, 10:30 PM   #1
mgold97
Th350 stock crossmember picture
Need to see some pictures of stock 81-84 c10 trans crossmemeber (th350). Previous owned had powerglide and since i put th350 in it there is no space for transmission mount, so i think he might of flipped crossmemeber over. Tried looking for some pix on google but nothing came up except aftermarket crossmemebers.
Thanx
mgold97 is offline   Reply With Quote
Old 03-18-2013, 11:16 PM   #2
rs74
rs74's Avatar
Re: Th350 stock crossmember picture
This is just a random photo off the internet but mine in my 85 sets the same way. Hope this helps. Not me laying under the truck either.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 03-18-2013, 11:23 PM   #3
mgold97
Thanx. Mine crossmember seems to be off 79 model with one wing on passenger side and flat part on driver side. Th350 I swapped in out of 72 truck, so should I replace my crossmembers to 72 or can I make my 79 work.
PS 1984 c10 350/th350 2wd shortbed.
Old 03-18-2013, 11:54 PM   #4
rs74
rs74's Avatar
I am not sure what the 79 crossmember looks like but these trucks came out with a 350 trans in alot of these trucks. I would think it would bolt right in. I am sure someone will chime in and give the correct info. Can you put up any photos of what you have?
Roy
1987 R10 shortie
Old 03-19-2013, 12:14 AM   #5
KrazyRay
KrazyRay's Avatar
76 and newer should have the single exhaust transmission crossmember. The passenger side will key into the frame just like earlier ones, but the driver side wraps around the outside of the frame. I will see if one of my parts trucks have the crossmember to get a pic. I sell a bunch of the 73-75 AT crossmembers for the guys that want to upgrade their 76+ trucks to dual exhaust.
KrazyRay is offline   Reply With Quote
Old 03-19-2013, 12:49 AM   #6
mgold97
I am 100 positive I have single exhaust member you are talking about. Can it still be used with 72 trans or do i have to swap? Trans tail laying right on crossmember and it seems to be too tight to slide trans mount it, but I might be wrong. Should I unbolt crossmember and trying bolting trans mount in or will it be out of wack anyways lol. Any input would be helpful.
Old 03-19-2013, 12:58 AM   #7
KrazyRay
KrazyRay's Avatar
The 73-75 AT crossmembers have a different profile then the 67-72 as I have put them side by side to compare. The 76 up or the 73-75 AT crossmember will solve your problem with any year TH350. Who knows what year crossmember is in there now as the powerglide was common in the pre 67 trucks.
Old 03-19-2013, 04:55 PM   #8
mgold97
Do you have one you could sell me? will I need to drill any new holes or just use existing one since its an 84 truck.
Old 03-19-2013, 07:13 PM   #9
KrazyRay
KrazyRay's Avatar
Here's pics of the AT single exhaust crossmember in a 78. I need to check my barn to see if I have a loose one. Your 84 should already have the holes for this crossmember.
Old 03-19-2013, 07:51 PM   #10
mgold97
Thats the one I have. What trans do you have on that truck? You saying this one will not work for 72 th350 or will it?
Old 03-19-2013, 07:55 PM   #11
mgold97
can I lift trans up with engine attached? Do I have to loosen motor mounts?
Old 03-19-2013, 08:03 PM   #12
KrazyRay
KrazyRay's Avatar
This truck has a TH400, but this crossmember also works with TH350. Your 72 trans should work fine and you should be able to lift it a bit without removing from the engine. What year transmission mount are you trying to use?
Old 03-19-2013, 08:07 PM   #13
mgold97
72. Should I try later year? I haven't put one on yet, since a seemed a bit tight, but i think it might work once i try to lift it up. Guy before me had powerglide just laying there on crossmember not bolted up,just loose. found out about it when doing my engine and trans swap 2 weeks ago lol.
Old 03-19-2013, 08:29 PM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
just to mention
there is a hight difference from a C to a K crossmember in the jimmys,
is there for the pickups?
FWIW,in my 81 Lemans i took out a 200 ,and the 350 slid right in
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-19-2013, 10:38 PM   #15
KrazyRay
KrazyRay's Avatar
Yes, The C and K crossmembers are much different.
Old 03-19-2013, 10:40 PM   #16
KrazyRay
KrazyRay's Avatar
Ask for a mount for an 84 with a TH350. Or fudge the year to 81 if that doesn't work.
Old 03-19-2013, 11:32 PM   #17
mgold97
Thanx for all your help guys. Just ordered 84 mount from summit and it looks way different from 72 I got now. Will have to wait and see what fits lol.
