Old 03-19-2013, 12:58 AM   #1
56SS
Gas Tank question
I know some of you guys out there have made your own gas tanks to mount under the beds, so I figured I'd see if anyone was willing to help me out.
I am looking to make my own tank that I want to fit the 2001 5.3L fuel pump in as well. I want to mount my tank right behind the axle, I think. I have a friend who is going to help me with some of the fab work, but I'm not sure how to go about my design and what measurements would be right. I believe the fuel pump is ~9.5 inches long, but I've never made a tank before, so I'm not really sure where to begin. Thanks in advance!
56SS is offline   Reply With Quote
Old 03-19-2013, 05:06 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Gas Tank question
Tank size is mostly a preference, aside from the natural limitations such as fitment.
Might help to tell us what year/truck it is?
If you know roughly where you want to put it, take some rough measurements of width, height and depth(length). Multiply them to get total area in cubic inches; 1 cubic inch = .0043 US gallons. That will tell you a rough internal capacity, minus things like baffles or tank foam, a sump etc.
A simple square/rectangle gas tank can be made mostly out of one sheet of stock if you have a break and make your marks right. Baffles are optional, but not a bad ideas. You can also use tank foam instead of a baffle, as some do.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-19-2013, 06:44 PM   #3
Robznob11
Robznob11's Avatar
Just buy a 4 gen camaro tank trim a little of the bottom of the frame , move the back b race back a little, remove small brace , and hole saw frame to fit filler hose. Walla you have it. I used a torch to do mine and 2x 1/4 thick aluminum strap to hang it. Look up project bruser for pics. I installed mine opposite of his 180 tur
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 03-19-2013, 10:09 PM   #4
56SS
Thanks for the info guys, I'll start to draw up some designs and start calculating
Old 03-21-2013, 01:44 AM   #5
mcmlxix
Collector of Projects
mcmlxix's Avatar
here are my plans ... be sure you plan ahead if you are using a sheet metal brake... compound bends make it difficult ....
one in progress pic...
Check out my build thread for more details...
Rich
1972 K5 Blazer CST Click HERE
