Old 03-19-2013, 11:39 AM   #1
62chevy302
hillbilly
62chevy302's Avatar
can this be fixed?
I dont know if this can be fixed. Im guessing with a parts cab? I NEED to use this cab. It has sentimental value. Anybody have any ideals about fixing it rather than getting a new cab? thanks
-1962 C-10
62chevy302 is offline   Reply With Quote
Old 03-19-2013, 12:07 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: can this be fixed?
Yes it can be repaired. Do you weld or have a friend that welds. You will need to find a donor cab with these sections in good shape and cut them out.
If it is really bad, you might consider splicing a complete roof on from a donor truck.
It is a lot of work and if the rest of the cab is good, well worth the time in my book.
My 64 has the same problem on the drivers side under between the windshield and the drip rail and when all the planets line up, I am going to repair it.
TBONE1964 is offline   Reply With Quote
Old 03-19-2013, 12:10 PM   #3
1963c-10
1963c-10's Avatar
I agree w/TBONE1964.....your going to have to take the top off another cab and do alot of welding.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-19-2013, 12:19 PM   #4
62chevy302
hillbilly
62chevy302's Avatar
Im afraid it will be hard to find another cab,especially one in better shape. I can weld as im welding in rockers,floor pans, kick panels. after i get them in im goin to start on this stuff
-1962 C-10
Old 03-19-2013, 12:26 PM   #5
1963c-10
1963c-10's Avatar
check w/some of the 60-66 parts venders out in the midwest or in the southwest. It shouldn't be that hard to find, you just may not like the price of shipping a part that large.
Old 03-20-2013, 12:43 AM   #6
Captainfab
60-66 Nut
If the extent of the rust is confined to mostly the areas in the pics, you can just weld in patches in thjose areas. Just be sure to cut away the rust to the point of getting into good solid metal. It is possible that I may have those pieces, that I could cut out of a parts cab. I would have to verify the integrity of those areas.
