Old 03-19-2013, 11:44 AM   #1
SFTorange
SFTorange's Avatar
Steering wheel, tach, fuel pump
Hi All,
Thought someone over here might be interested in these parts.
Clamp-on 2.5" column mounted tach. $22 shipped.
Holley SBC mechanical fuel pump. Model 12-834 80 gph. Used, but barely... $40 shipped.
Steering wheel from '89 GMC $35 shipped.
The Brown Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=437222
SFTorange is offline   Reply With Quote
Old 03-19-2013, 11:48 AM   #2
jhiggy94
Re: Steering wheel, tach, fuel pump
interested in the tach and the fuel pump... What has to be modified to use the tach in our trucks? Or is it simply wiring it in? Sorry i dont have much experience with this. And does it come with everything necessary for it to be installed?
jhiggy94 is offline   Reply With Quote
Old 03-19-2013, 12:05 PM   #3
SFTorange
SFTorange's Avatar
I'm sure someone could chime in here about installing the tach. It is pretty much a direct plug and play with an HEI distributor, but I'm not sure for a points setup. I still think it's pretty easy. You just have to plug into a feed from the distributor, a ground, and a 12v ignition source.
The wires are a bit short, but would be easy to extend. You can install it by using a big hose clamp around the column, or make your own setup in some other location.
The Brown Truck
Old 03-19-2013, 12:06 PM   #4
HotRod C/10
HotRod C/10's Avatar
I'll take the tach
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 03-19-2013, 12:21 PM   #5
SFTorange
SFTorange's Avatar
jhiggy94 is first in line for tach, if he turns it down, it'll go to HotRod C/10.
The Brown Truck
Old 03-19-2013, 12:23 PM   #6
jhiggy94
Im not sure if i have first dibs or if hotrodc/10 does... But i will take the tach. I will pass on the fuel pump
Old 03-19-2013, 12:24 PM   #7
jhiggy94
you can pm me your paypal.
Thanks,
Jake
Old 03-19-2013, 12:26 PM   #8
HotRod C/10
its yours
LS SWAPPED
-1976 SILVERADO
Old 03-19-2013, 12:38 PM   #9
SFTorange
SFTorange's Avatar
Tach sold to jhiggy94! Thanks!
The Brown Truck
Old 03-20-2013, 09:37 AM   #10
SFTorange
SFTorange's Avatar
Top
The Brown Truck
Old 03-20-2013, 12:24 PM   #11
zicc1835
zicc1835's Avatar
Ill take the fuel pump if you will do 30. Shipped
zicc1835 is offline   Reply With Quote
Old 03-20-2013, 02:51 PM   #12
SFTorange
SFTorange's Avatar
Split the difference, and we have a deal. $35 shipped to you.
The Brown Truck
Old 03-20-2013, 09:41 PM   #13
SFTorange
SFTorange's Avatar
Tach shipped out today. Thanks
The Brown Truck
Old 03-21-2013, 12:10 AM   #14
zicc1835
zicc1835's Avatar
Ok send pp info
Old 03-21-2013, 09:39 AM   #15
SFTorange
SFTorange's Avatar
PM Sent
The Brown Truck
Old 03-21-2013, 10:38 AM   #16
zicc1835
zicc1835's Avatar
$s sent thanks
Jz
Old 03-21-2013, 11:03 AM   #17
SFTorange
SFTorange's Avatar
Thanks! I'll ship it out tomorrow.
Someone take this wheel off of my hands!
The Brown Truck
Old 03-21-2013, 11:22 AM   #18
vernon71
Does the steering wheel come with everything to hook up the horn?
vernon71 is offline   Reply With Quote
Old 03-21-2013, 12:43 PM   #19
SFTorange
SFTorange's Avatar
Part of the horn contacts are located in the "GMC" cover plate, but I wasn't able to get it to work. I do think it can be done, however.
The Brown Truck
