Old 03-19-2013, 01:02 PM   #1
olskool68
Does lowering change drivetrain mounts?
Hey folks, getting to the point where all my major pieces (engine, tranny) are getting wrapped up but I have a question. I've installed a 3" CPP drop axle and 3" drop mono's on the front. Not sure yet what I'm doing to get the rear that low (Flip vs reverse eye mono).
The engine is a 235 but we are going with a 200 4r tranny so the mount will be a crossmember from CPP. Does a static drop of 6" or more change how the tranny will sit if I'm using the original motor and motor mounts? Or can I just buy the crossmember and call it safe? In most cases, I see that changing the spring pads on the axle happens so is the pinion angle different when lowered?
Thanks guys. This is my son's 58 Apache fleetside.
Struck down, but not destroyed 2 Cor 4:9
1958 Apache 32
olskool68 is offline   Reply With Quote
Old 03-19-2013, 01:15 PM   #2
NEWFISHER
NEWFISHER's Avatar
Re: Does lowering change drivetrain mounts?
Not unless you are laying frame and need to "tuck" the trans/driveline etc. When you hang the 2004r from the adapter and set the cross member, make sure the tail shaft is at 3 degrees down. I used a non-ratchet tie down looped over the frame rails and hung the tailshaft high. I shortened the ends of the crossmember to fit inside the rails and then bolted it to the trans. Lowered it down while watching the degree gauge until it rested at 3 degrees and tacked in the cross member. You also want the rear pinion measured at flange up 3 degrees.
NEWFISHER is offline   Reply With Quote
Old 03-19-2013, 01:23 PM   #3
olskool68
Originally Posted by NEWFISHER View Post
...make sure the tail shaft is at 3 degrees down. I used a non-ratchet tie down looped over the frame rails and hung the tailshaft high. I shortened the ends of the crossmember to fit inside the rails and then bolted it to the trans. Lowered it down while watching the degree gauge until it rested at 3 degrees and tacked in the cross member. You also want the rear pinion measured at flange up 3 degrees.
Thanks for the reply. Is it best to have the frame level on stands before making the degree adjustments?
1958 Apache 32
Old 03-19-2013, 01:48 PM   #4
98layinframe
98layinframe's Avatar
You want the vehicle sitting close to its normal ride stance that way the motor will be sitting at 3° while driving.
Also since its a leaf sprung vehicle, your gonna want to set the rear pinion at 2° instead of the normal 3° only to help compensate for the axle wrap associated with leafs when under throttle.
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 03-19-2013, 02:32 PM   #5
dubie
dubie's Avatar
I have the same axle and leaf drop up front as you and I'm running 6" reverse eye mono's on the back. I set my pinion angle on my diff at 2 degrees up and the tail shaft at 3 degrees downward.
Did you install any caster shims up front? Once you lower it that far you need to re-adjust your caster. I bought a 6 degree shim kit from Performance online
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 03-19-2013, 07:50 PM   #6
_Ogre
_Ogre's Avatar
the mounts are basically the same, but...
the trans mount is about the easiest thing to fabricate on your truck
why buy a piece of pipe?
shop air compressor timer
Old 03-19-2013, 08:27 PM   #7
mechanixman
mechanixman's Avatar
Maybe this will help
http://jniolon.clubfte.com/driveline...nephasing.html
-Nick
Projects:
1952 Chevy 1 ton = The Build page
mechanixman is offline   Reply With Quote
Old 03-20-2013, 12:54 PM   #8
olskool68
Did you flip the axle or just go with the mono's? I did install the 6 degree shims. i was going to go with the 4 but read enough on here where 6 was what most folks agreed on.
1958 Apache 32
Old 03-20-2013, 01:55 PM   #9
dubie
dubie's Avatar
i used a set of reverse eye mono's in the rear to drop it 6 inches to match the drop in the front
Old 03-22-2013, 02:36 AM   #10
olskool68
Thanks for all the replies, gents. I decided to go with the flip kit and adjust from there.
1958 Apache 32
Old 03-22-2013, 02:38 PM   #11
sqrlnts
I noticed with mine (very similar to Dubies setup) that the center frame cross support above the trans tailshaft is very close (~1/2") to the driveshaft. I have had no problems with it contacting but I don't have a bed floor. This may become an issue for me once I try to haul a load, if that day ever comes.
sqrlnts is offline   Reply With Quote
Old 03-22-2013, 06:31 PM   #12
butchp
I would get the rear setting where it is going to be berore I tried to set any angles.
butchp is offline   Reply With Quote
Old 03-23-2013, 06:47 AM   #13
olskool68
That's the kind of advice I need to hear! Thanks. I'll watch for that.
1958 Apache 32
