03-19-2013, 03:47 PM | #1 |
Need help sbc 350 wont start
I have a 73 350 and it's hasnt been starting i found that I needed to rebuild the carb got it rebuilt and it started but then ran outta gas so i got more gas and havent been able to get it started and it doesnt even seem like it wants to. Some one please help
03-19-2013, 03:50 PM | #2 |
Re: Need help sbc 350 wont start
Is it getting spark? check the plugs and wires.
03-19-2013, 03:51 PM | #3 |
Its getting spark, its getting fuel. And thats what throwing me off. Ive checked timing and all that is right
03-19-2013, 04:03 PM | #4 |
78K & 79C Jimmys
is it getting enough gas
try using a cleaned out plastic pop bottle,poke a hole in the cap,squirt in carb use it to supply gas see if it keeps running....then check lines and filters
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-19-2013, 04:06 PM | #5 |
Ya its getting enough gas and i changed the filter cause it was bad.
03-19-2013, 04:11 PM | #6 | |
78K & 79C Jimmys
seen those fulla rusty crud,flows back to the pump when off any vacume leaks(obvious ones),hoses off? maybe two filters?
03-19-2013, 04:13 PM | #7 |
Ill check the lines but theyre no vacuum leaks
03-19-2013, 04:33 PM | #8 |
The lines r clear and im getting good pressure
03-19-2013, 04:37 PM | #9 |
This might sound a little crazy but due to it happening make sure all your cables on your battery are tight and didn't come lose and then check your ground too.
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
03-19-2013, 04:39 PM | #10 |
Ive checked all that and ive checked for spark and getting the right voltage to and from the distributor so im comeplety stumped
03-19-2013, 06:14 PM | #11 |
It's not getting something, spark (at the right time), fuel, and compression is all it takes for a motor to run (not necessarily well). Something is missing somewhere.
03-19-2013, 06:48 PM | #12 |
Since you just had the carb apart look for signs that something isn't right fuel wise first.
Are the plugs wet with gas/fouled black? This would indicate too much fuel, the float needle might not be sealing or the float set to high allowing gas to spill out the top of the bowl and run down inside. Needles could be set wrong, generally most carbs will idle with the screws about 2 turns out from seated. Might not run good, but it will usually start and run. If you pour a little gas down the neck does it at least try to hit a few times and maybe belch a little black smoke? The needle might be stuck in the seat or the float set to low and no fuel is getting in the bowl. When you pump the pedal do you see fuel squirting out the accelerator pump holes? If not there is no gas in the bowl for one reason or another. Did you install the filter the right way (Quadrajet?) They only flow one way. If you pull the hose off the pressure side of the fuel pump do you get any gas when cranking? If you do get gas out the pressure line, but no gas out the accelerator pump holes there is for sure something wrong with fuel getting in the bowl of the carb (filter, needle, plugged passage, something). If no fuel comes out there is either no fuel available to the pump, or it is not pumping anymore, the diaphragm dried out and ripped. A dry fuel pump diaphram is not uncommon if it's been sitting a while. Has it been sitting a while? Is it possible you just have bad gas? |
03-19-2013, 07:15 PM | #13 |
Imma completly check the carb again. Its brand new gas 91 octane
03-20-2013, 12:19 AM | #14 |
I took the plugs out and found they were flooded so i let it all dry and adjusted the carb more and it wants to start but still wont
03-20-2013, 12:51 AM | #15 |
Sounds like it is really flooded, maybe a bad carb rebuild. Or could just be flooded really bad.
Safe way, take the plugs out and let it sit with them out over night. Hillbilly way, take the plugs out, take a lit propane torch and light each cylinder hole until dry and no poof. Be careful here, keep an extinguisher handy. Works even better if someone turns the motor over a bit while doing this. Then try to start it up after doing one of the above. If it runs, great. If it fires up and runs ****ty, we can then isolate the problem further.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
03-21-2013, 10:36 PM | #16 |
Ive tried everything, it has gas getting to it, it has spark and gettingh compression. Its started to try and start but wouldnt so i adjusted the time a little and now nothing at all again
03-22-2013, 05:48 PM | #17 |
Can any one try helping me more. Idk what else to try. Once again it has good compression, its getting fuel, spark. I just gapped the points to double check yesterday and theyre good and got everything on TDC and all that and it still wont try and start so idk wat else to do now
03-23-2013, 01:48 PM | #18 |
I have an 85 and have a similar problem it turns slowly even with a new battery and a 50 amp charger on it and I have weak spark. I have replaced the plugs, wires, distributer cap, rotor all the electrical components for the distributor. including the pickup coil and its still weak.
03-23-2013, 07:25 PM | #19 |
Im getting full cranking power, I noticed i wasnt getting all spark in the points so i put new ones and was getting all spark and getting all better spark ever where but still nothing. Wont start tried to a couple times then nothing again. So idk wat else is would b or watelse to try
03-24-2013, 09:40 AM | #20 |
78K & 79C Jimmys
hold the pos on the batt .neg on the dizzy base
crank, confirm voltage(check wires going in for cracks weakness)
03-25-2013, 02:51 AM | #21 |
Come to find out its cuz of the timing chain
03-25-2013, 07:40 AM | #22 |
What's wrong with the timing chain? Is it broken or the gear stripped?
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
03-25-2013, 02:00 PM | #23 |
I was going to say check your timing, like was posted, all an engine needs to run is Spark and fuel, but the spark has to be at the right time. If you getting fuel and getting spark and still no run, then the only thing left is timing. That sounds like what you discovered.
08-20-2013, 11:30 AM | #24 |
i have a 305 sb and it was working fine but i needed to change my intake manifold so i did and it started up but when i would put in gear now it sounds like if it wants to turn off and kinda shaky? and i had to take the rotor back off to tightened the intake more on the back and i tried putting the rotor exactly back were i took it off but now the engine sounds kind of rough when it starts could that be due to timing? or due to maybe some water getting into the engine due to the intake being loose?
