Pipe wrench?
Any of you lose the key to one of these. Know an easy way to remove ?
Posted via Mobile Device Posted via Mobile Device Sorry it's upside down but u get the idea Posted via Mobile Device
72 GMC super custom. ![]() |
the boat guy
Remove slowly says it right there on the cap silly....
![]() Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
Re: Pipe wrench?
Lol. Leaning towards channel locks or pipe wrench but don't want to hurt the tank neck
Re: Pipe wrench?
drill out the lock so the pin n springs come lose, remove as normal.
Re: Pipe wrench?
Drill but same size as key assembly?
Re: Pipe wrench?
I'd say drill it out, but you want to be careful to not get shavings in the tank if you go too far
71 K20 64 GMC mud truck |
Re: Pipe wrench?
Call a lock smith, drilling may cause your tumblers to fall into the tank.
![]() Join Date: Jan 2001
Re: Pipe wrench?
Drilling around fuel vapor is not my favorite idea.
I would try a screwdriver first. The metal those caps are made out of is not very stout. I'd bet you could force the lock with a screwdriver. If not, I'd try prying it off with a screwdriver. |
Re: Pipe wrench?
run a 1/4" bit down the center about 3/4-1" deep, then run the drill backwards, then grab the large screwdriver.
nothing will get in the tank[less ya drill farther then 2-3in in], if it did, it would do nothing, only gas soluble particles can make it past the pick up sock in the tank. metal don't dissolve in gas. truckster, the guy uses a gas tank for a back rest [he has no fear], all sort of electronics, probably people smoking, done would of blown up long ago or drove off the road from them being sucked into the window 3in away or door jam with a 40yr old seal, if he has vapor problems that a drill would make it explode. |
Re: Pipe wrench?
Though yes better safe then sorry but, a gas tank 4in from your seat back takes a set of brass ones to begin with and would take a perfect storm of condition to even consider a drill making it explode, if he doesn't think twice about resting his head on the tank for comfort, I can't see a one in a million chance of blowing up is even a concern
Re: Pipe wrench?
It's a 72 witch should be vented so I don't think it's built up with pressure but ya I wondered bout drilling on a gas cap rather not burn up lol. Wondering about locksmith since my ignition key is missing too and i have heard the doors and ignition were the same key on these trucks if its all original witch I believe it is
Re: Pipe wrench?
Guess I have always loved the cab tanks since I was a kid and. Probly the wrong way to think but if it has lasted this long with no problem must work ok unlike ford pintos original gas tank witch exploded when rearended lol
#13 |
Registered Cruiser
Re: Pipe wrench?
Those are pretty cheap locks. Try any key that will go into the keyway. It might open. I'm certain I could easily pick that lock.
I intend to live forever. So far, so good. |
#14 |
People know me
Re: Pipe wrench?
Prefferably a torch or plasma cutter if you have one, If not a grinder with a cut off wheel.
Or you could just use a pair of channel locks, they are not very stout and come off easy
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
#15 |
![]() Join Date: Sep 2012
Re: Pipe wrench?
I have one just like it on a shelf in the garage. If you haven't tried anything yet....I can go take a look at it and maybe see what I can do with it..........
#16 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Pipe wrench?
I screw a slide hammer down into the lock and thump it a few times. Pieces go flying everywhere.
Posted via Mobile Device |
#17 |
Re: Pipe wrench?
Scott>72-GMC
Ask member LockDoc he probably has some ideas
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
#18 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Pipe wrench?
Tow truck drivers have a pick for gas caps in their lock out kit. Most gas cap locks are two or three tumblers fairly easy to pick. I have one in my tool box but I aint crazy enough to drive that far
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#19 | |
Re: Pipe wrench?
#20 |
Re: Pipe wrench?
Let me go see. It's on top of my tool box
#21 | |
![]() Join Date: Oct 2009
Re: Pipe wrench?
#22 |
Re: Pipe wrench?
I have done it twice the same way Txfirefighter said should work. It does work and just like he said parts go FLYING!!!!
#23 |
Re: Pipe wrench?
Dremel will work best. Cut around the red ring. Metal is only about 1/16" think. If you don't have a Dremel....drill little holes and connect the dots.
There's about 1/8" between that metal cap and the rubber seal. So no worries. Once you get outter ring cut off cap you can cut back rubber grommet with a knife and then just stick two small screw drivers in and depress the tabs. The tabs are at 12:00 and 6:00 looking at the key hole. |
#24 |
Re: Pipe wrench?
#25 |
Re: Pipe wrench?
Awesome thanks
