Old 03-19-2013, 05:10 PM   #1
2772
2772's Avatar
Why not?
31x10.5r15 on 15x10. Looks OK to me. What's up with the approved rim being only 9 for that size tire? If I did this right, you should see pictures.
FEEL, FEEL, FEEL , FEEL MY HEAT!
2772 is offline   Reply With Quote
Old 03-19-2013, 06:42 PM   #2
stomper
Junior Member
stomper's Avatar
Re: Why not?
I like the wider rim look. They're hard to mount sometimes - to get the tire to seal on the rim so you can inflate it.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 03-19-2013, 08:43 PM   #3
ole dollor
ole dollor's Avatar
Re: Why not?
i use to see a lot of people do this, as long as you watch the air psi. and keep it full of air i think it should work...
ole dollor is offline   Reply With Quote
Old 03-19-2013, 09:08 PM   #4
2772
2772's Avatar
Re: Why not?
Yeah, very hard to mount.
Old 03-19-2013, 09:10 PM   #5
2772
2772's Avatar
Re: Why not?
Been ridin like this for a few months. No problems. Don't see the big deal. Is it really that UNSAFE? If so why?
Old 03-19-2013, 09:13 PM   #6
hotstuff
Re: Why not?
the recommendation is for side wall protection , from what I've been told
hotstuff is offline   Reply With Quote
Old 03-19-2013, 09:21 PM   #7
ole dollor
ole dollor's Avatar
Re: Why not?
i think the tire people will say it would be unsafe, because the ballooning of the tire and the wide rim would make it hard to air up, also if it were low on air in a sharp turn it could roll off the wheel. but almost any low tire can . i also think that the side wall would be more pron to be damaged easier...but like i said i have seen a lot of people run like this , and not have any trouble. i kinda like the looks. and would run them if that is what i had. i would just keep an eye on the psi....
Old 03-19-2013, 09:59 PM   #8
2772
2772's Avatar
Re: Why not?
Idk. I don't like how the tire is "ballooning" now think I'm gonna try to find some 15x9 or something and go with a nice highway tire.
Old 03-20-2013, 07:35 AM   #9
Re: Why not?
I think the recommended rim width has to do with proper tire wear. When the rim is too narrow the tread will "crown" and wear the center faster. With a wider than recommended wheel the tread dips and the outer tread wears faster. There are different degrees of over/under and a 10" wheel with a 10.50 tire is first notch high. The actual tread width is an inch or so less and you don't want a tread surface narrower than your wheel width for proper contact
Old 03-20-2013, 07:50 AM   #10
b.eddy's72
b.eddy's72's Avatar
Re: Why not?
My step brother ran like this with 15x10's on his Cutlass for years cause the wider tire would rub the fender well. I personaly like more tire than rim but to each his own. It doesnt look bad.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new.
66 GMC Short Step, 84 Front Suspension, many more mods to come
67 Chevy 3/4 Ton, 327, Auto, Factory A/C
Ya must have been movin cause I was haulin a*$ when I passed you
b.eddy's72 is offline   Reply With Quote
Old 03-20-2013, 09:17 AM   #11
Re: Why not?
If you want the 10" wide wheels you just need wide lower profile tires. This truck is lowered 4/4.
Edit: Now that I look at these pictures,he could have used wider tires,too. He had about the same situation as yours. Those came on that black '85. He now has 10" Vette-style rallyes with new tires that fit right. They're a tad taller,too,and the truck now has -6" rear springs
Old 03-20-2013, 02:27 PM   #12
2772
2772's Avatar
Re: Why not?
As you can see I have 15x10 Bette style rally too. What tire did he use?
Old 03-20-2013, 02:29 PM   #13
2772
2772's Avatar
Re: Why not?
I like more tire than rim too. Just want to br able to stick out past the fender well a tad
