Old 03-19-2013, 06:46 PM   #1
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Question Wire Tape Replacement (non-sticky)
IIRC, 67cheby or someone else found a replacement tape material for wrapping wiring up to make it look stock but it kept it from getting sticky like electrical tape.
Does anyone else recall this?
If so, link to more info and any experience with this product.
It very well could have been a wire loom type material as well but kept the stock look.
Thanks in advance guys!
Nate
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-19-2013, 06:54 PM   #2
cdowns
cdowns's Avatar
Re: Wire Tape Replacement (non-sticky)
eastwood is one place that comes to mind that sells the wire wraping tape// it comes out good after a bit of practise and the right technique for starting and ending the wrap is mastered
Old 03-19-2013, 06:55 PM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
http://motors.shop.ebay.com/i.html?_...g+harness+tape
http://monarorestorationparts.com.au...d-NEW-OEM.html
Here are a couple of sources for you. You may even be able to get this through NAPA or a normal parts store.
I would think anyone who sells restoration parts should stock it.
TBONE1964 is offline   Reply With Quote
Old 03-19-2013, 07:37 PM   #4
FirstOwner69
FirstOwner69's Avatar
Try this link.
http://www.classicindustries.com/truck/parts/k0067.html
FirstOwner69 is offline   Reply With Quote
Old 03-19-2013, 08:06 PM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Thanks for all the info guys.
Has anyone used this stuff (or equivalent) before?
How does it adhere if it is non-stick? Heat?
-Nate
Old 03-19-2013, 08:09 PM   #6
jocko
jocko's Avatar
i have used the non-sticky wire loom "tape" that Year1 sells. Probably the same as all the above (exactly like the classic industries tape) - works fine. It is NOT the cloth stuff you see listed on some of the ebay returns. Takes a little more patience to use as it it will unwind since it's not sticky (until you finish wrapping and get the end tied down). I'd practice with a few short lengths first to make sure you have the wrappin, and more importantly, end tie procedure down before you wrap on your actual harness. Might be under-estimating your wire wrapping cababilities, but I know I had to practice a bit (ok, SHOULD have practiced a bit) before I got all tangled up in it for real.
Old 03-19-2013, 08:34 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Thanks for the insight Jocko.
Does the "tape" tie onto itself or do you use something else to tie it off?
-Nate
Old 03-19-2013, 08:46 PM   #8
Sloan66
I used the non adhesive vinyl that Tbone linked to on ebay, worked great. And yes the original looms they tied to themselves without anything else.
Sloan66 is offline   Reply With Quote
Old 03-19-2013, 09:04 PM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Thanks Sloan66!
There's one on Ebay for 2 rolls for $6.99. I assume on the rubber style, one is as good as the other.
I'm not a big fan of the cloth style.
-Nate
Old 03-19-2013, 09:54 PM   #10
davischevy
davischevy's Avatar
I've seen it both ways, tied and taped.
davischevy is offline   Reply With Quote
Old 03-19-2013, 09:58 PM   #11
jocko
jocko's Avatar
what sloan said - factory tied em. But i've seen people do it both ways on rebuilds. Either looks fine, but I think the slightly messier looking tied off way is more factory correct.
