Old 03-20-2013, 07:56 AM   #1
Ironhorse
Ironhorse's Avatar
4x4 1/2 T vs. 3/4 T Drive Shaft - Same?
Looking for an answer since I have no idea. Is a rear drive shaft from a 1/2 ton 4x4 LWB verses a rear drive shaft from a 3/4 ton 4x4 LWB inter-changeable or compatible? Have a shaft from my 1/2 ton 4x4 for sale on the parts board and a fellow member is interested but is looking for a drive shaft for his 3/4 ton 4x4. Will the shaft I have work for him? Both trucks are '71-'72 sm465/np205 set-ups.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 03-20-2013, 10:07 AM   #2
ERASER5
ERASER5's Avatar
Re: 4x4 1/2 T vs. 3/4 T Drive Shaft - Same?
U-joint is a different size most likely. Mine was. The length might work, might not. The 3/4 ton sits taller than the 1/2 ton making the D-shaft slightly longer. Think of a triangle with the hight being the truck, and the length being the linear distance from the front U-joint to the axel. The d-shaft is the hypotenuse. As the hight get taller, the d-shaft get longer. The slip joint can only absorb so much difference. On my truck, I am hoping the new springs will give some lift so I don't have to cut my d-shaft. I only have a bit more than a 1/4 inch of movement in one direction.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-20-2013, 04:45 PM   #3
argonaut
argonaut's Avatar
Its also dependent on powertrain and towing capacity. The more powerful the motor the larger diameter, or thicker the walls or the driveshaft to withstand the torque. Same thing for u-joint sizes. And same thing if you are hauling/towing heavier loads, the drivetrain is subject to greater forces and torques.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 03-20-2013, 10:38 PM   #4
odog
odog's Avatar
I took the drive shaft from my3/4 ton 67 and put it in my1/2 ton 69. No difference. Both were 4x4. The 3/4 ton had an Eaton rear end with an sm 420/221 trans transfer combo and the 69 had the same trans transfer combo but a 12 bolt rear end. No problems, the drive shaft was a 2 piece with a carrier bearing.
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 03-20-2013, 11:29 PM   #5
budman k20
1972 K20
I have never seen a 2 pc driveshaft on a 4x4? Must be pre 71 technology. I know for a fact my 72 3/4 4x4 has larger u-joints than my 71 1/2 ton 4x4. Same for the front shaft as well.
budman k20 is offline   Reply With Quote
Old 03-20-2013, 11:40 PM   #6
mud.man.rj
mud.man.rj's Avatar
I have done it before and believe the ujoint size was different so I used the combo joint which is 2 different cup sizes so fits shaft and fits pinion.
mud.man.rj is offline   Reply With Quote
Old 03-21-2013, 10:14 AM   #7
Ironhorse
Ironhorse's Avatar
Thanks for the replies on the drive shaft question. Seems like others have done it but does involve using differant u-joints. Will PM the interested party and let him decide. Again, thanks for the replies, always learning from this board.
Wellington, Ks
Old 03-21-2013, 09:51 PM   #8
odog
odog's Avatar
Sorry, I forgot to say I used a combo u joint on the rear end, everything else was the same though.
1969 4x4
