What tires on '96 2WD Tahoe? -Currently Unstable!
What tires would be best on a '96 2WD Tahoe? It currently has 235/75R15's on chrome 454 SS wheels. It flops around like a fish out of water and feels extremely unsafe over 40 mph. I can slowly flick the wheel back and forth and it feels like the back is swaying 4-5 inches left to right while driving, it's very unnerving at speed! It feels like it would roll over if we had to avoid something in the road. It's lowered 3.5" with spindles in front and 2" rear with adjustable shackles.
It has cheap "Star Fire" tires on it now but it's done it with other tires too. I know that it's going to have some sidewall flex with that tall of a tire but this much flex is ridiculous. I can't talk the owner (my parents) into going with 18's or 20's to shorten the sidewall. Would adding a rear sway bar help? I currently only has a front bar.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
![]() Join Date: Oct 2006
Re: What tires on '96 2WD Tahoe? -Currently Unstable!
shortening the sidewall will give it a rougher ride. I think the 235/75's are a 29" tall tire and kinda narrow.Maybe a "70" or "60" series would make it handle much better, and yes a rear sway bar will help with body roll. Also check your shocks and bushings.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
It has had new Monroe shocks recently. We had 255/70's on it and it did the same thing, maybe not quiete as badly though. I don't think shorter tires would look right, its not low enough so the wheelwells would be to open.
I've seen rear sway bars on 4WD tahoes, did they make a 2wd rear bar from the factory?
TNT-MOTORSPORTS
I had a 2000 OBS tahoe limited and I know exactly what you are talking about. It was bad enough my wife didnt like driving it. I never did cure it either. It got better when I put 20's on it , but it was still there. Mine had a big swaybar on the front, larger than a normal tahoe (not sure of the size, but was stock on a limited). Mine only had 85K on it so it wasnt a worn out pos..... but I never did find a cure. Be interested in the answer myself.
Charlie Daniels w/ a Tq Wrench
So are you having side to side sway from the tires? Or are you experiencing body roll? They have two different feelings. A rear sway bar will greatly help the body roll, but won't really help the side to side sway of tires with soft sidewalls. You could consider going up to a LT tire, assuming your current 235s are P rated, it will make the ride a little rougher, but will help with the sidewalls flexing.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
#6 | ||
TNT-MOTORSPORTS
[QUOTE=theastronaut;5959738]Good to know that 20's helped, how did they affect the ride quality? I'm thinking that larger wheels, urethane leaf spring bushings, and a rear sway bar would make it much better.
I did 20X8.5 Boss 338 on 275/45/20, they really werent tall enough , but my wife wouldnt let me lower it, It didnt seem to affect ride much at all, but it definitely helped the tire sway issue. You could rock mine sitting still also. I had new shocks, poly sway bar bushgs etc....couldnt make it go away 100%. Ive had other tahoes that didnt have that problem. |
You may want to consider new leaf springs. After replacing mine in my truck it was night and day difference.
Mike |
There is A LOT of weight in steel and glass over the rear wheels. You should feel the sway in the longer wheelbase of a Suburban. A lot of what you're feeling is just the nature of a big SUV. A rear swaybar will help to flatten it out in turns, but most of that sway is from the tall sidewalls. Shorter sidewalls would do a lot to calm that issue down. Some 17s or 18s and some tires with enough sidewall to keep the overall height near stock would make it a lot better without sacrificing much ride quality, but if your parents don't want to go with larger wheels, then there's really not much you can do about it other than shorter tires, but you're right, with such a mild drop, that can look a little off.
#10 | |
Her old Suburban: ![]() Same wheels, years later on our C1500 work truck, just a better picture that above.
| Bookmarks |
