Old 03-20-2013, 03:57 PM   #1
Vette_kid
Suspension Swap
Hi guys, I was just wondering I have read alot on here about swapping the 4 wheel drive suspension in a 1970 Jimmy/Blazer with two wheel drive. I was wonding if the suspension out of a 73 suburban will swap right over with no problems? the front and rear and the tranny crossmembers?
Vette_kid is offline   Reply With Quote
Old 03-20-2013, 04:54 PM   #2
zammer
Addicted user
zammer's Avatar
Re: Suspension Swap
Yes you can, this has been covered a couple times here and many have done it... Use the search and you will see lots of info..
Also check this out:
http://www.sporttruck.com/techarticl...wd_conversion/
- As for swapping out with your 73' suspension if it is from a 2wd the front crossmember should fit i believe and try to grab some trailing arms for the rear end or a 4 link set-up..
WElcome to the board!
1972 2wd Blazer - 95% completed
2015 Silverado 1500 4wd -z
2008 AERO 9-7X (TBSS cousin) LS2
1970 Jimmy 4wd - future project
zammer is offline   Reply With Quote
