![]() Join Date: Jul 2012
WTB: Dual Horns High and Low
Im looking to buy a set of dual horns. I have the factory harness, but no horns. I have a second dual horn harness as well id be willing to sell or trade. Let me know what youve got.
"Rusty" 1972 K20 Cheyenne Super, 496, A/C, Tilt, Tach, Buckets, 4l80e/NP205, 4" Rancho Lift, 35" BFG AT "Ramp Truck" 1972 C30 Ramp Truck 350, Air Bags, Factory A/C. "1968" C10 Shortbed project |
Go Pack Go!
Re: WTB: Dual Horns High and Low
I've got a set, tested individually but no harness to hear both. Will sell for $25 plus the ride. Can get a pic tonight.
#3 | |
I'm interested. you can post here or email pics to nitrosport_5@Hotmail.com Posted via Mobile Device
![]() Join Date: Aug 2008
I pulled a few parts off a 72 highlander in a local yard, including the dual horns and harness, then decided I wood buy he whole core support, so I left he horns on it. They pulled it for me but when I went back to pick it up, one of the horns was gone (!) and they don't know what happened to it. Nice.
Does anyone know the background on the dual horns, was it an option shown on the spid label, or part of another package, or what? I know most of the Cheyennes I have seen had them, and this highlander did as well. I am going back tomorrow to see if I can find the second horn. I don't know if it was the high or low note one. I think it was the one nearest the fender. Does anyone know if it was the high or low note in this spot? Would a truck with one horn have the high or low note horn? My luck is the horn they left is the same as what I already have and they lost the one I need. Posted via Mobile Device |
![]() Join Date: Jul 2007
I have a couple horns; but how can you tell the Low from the High?
Thanks Rock C
72 chevy 3/4 ton 4X4 |
![]() Join Date: Jun 2011
the high note will have a :H : stamped on it the low will have no stamp
Go Pack Go!
I found my crusty set I pulled off a WI truck, not sure if they work. I can't find the good set I bought some years ago. Sorry.
I would be interested in a pair of working horns after nitro sport finds his.
#9 | |
still looking for a set for now! Posted via Mobile Device
Go Pack Go!
K, charged battery on truck, tested each. One didn't work, other sounded really sick. Guess they go to the scrap pile. I also spent some time looking thru my good parts and can't for the life of me find the good ones.
![]() Join Date: Jun 2007
[QUOTE=WIDESIDE72;5960268]
Does anyone know the background on the dual horns, was it an option shown on the spid label, or part of another package, or what? I just took a set of these off a 1970 CST I found at the salvage yard to put on my own 70 CST, and they were listed on the Spid label as a separate "dual horns" option....I thought it was really cool because I never knew there was an option like that before I read the label and then went under the hood to find them. Nice little green jumper harness between them too....pretty neat |
#12 | |
Still in need of a set if anyone else has a set! ![]()
#13 |
![]() Join Date: Jan 2013
I believe the one nearest the fender is the lo.
#14 |
Nitrosport
Interested in your spare harness. How much you looking to get? Thanks, Tbruz |
#15 | |
not sure. what's it worth? bump still looking Posted via Mobile Device
#16 |
I went back to the yard today to pull some more stuff and found the other horn. It has a "H" on it! I already got the jumper wire and the rad support had the low note horn on it still. Now to see if they work! I also found another high not horn in my junk. The bracket on it is not quite the same. I plan to test it as well.
#17 | |
want to sell the pair? :-D Posted via Mobile Device
#18 |
#19 |
![]() Join Date: Aug 2012
#20 |
How badly do you want dual horns?
i had a 71 El Camino in high school (years ago) and if I remember correctly they are the same, just need the bracket bent to fit the 67-72 trucks. http://www.ss396.com/mm5/merchant.mv...ct_Code=ADR-3H http://www.ss396.com/mm5/merchant.mv...uct_Code=27730 |
#21 |
Its your part Nitrosport,
Don't want to insult anyone, you set the price you'd like to get for it. Tbruz |
#22 | |
![]() Join Date: Jun 2005
Thanks, Mark
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#23 |
![]() Join Date: May 2007
FYI...non working, and sick sounding horns, will usually be fine if you spray a bunch of wd-40, or something similar inside and let soak awhile.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
#24 |
I'll give it a try, thanks.
#25 |
Bump, still looking
