Old 03-20-2013, 06:15 PM   #1
rmmurphy
need electrical help please
i have a 68 short step 327 auto. i started my truck leaving work today. The starter stayed engaged (its a new rebuilt starter only about 60 days old.) so i shut the truck off and tried it again with the same result. this time with smoke coming from under the dash. The smoke was coming from the ign. switch. I didnt have much time to troubleshoot much more. I'm going to make the 30 mile drive back tonight to look at closer. Any ideas anyone?
rmmurphy is offline   Reply With Quote
Old 03-20-2013, 06:48 PM   #2
asolde
asolde's Avatar
Re: need electrical help please
I believe it is your ignition switch. You should be able to buy it at you local parts store. I had the same thing happen to me but havent taken the time to change it yet. I have the new switch in the garage I might do it this weekend. Seems like it's a little bit of a project.
asolde is offline   Reply With Quote
Old 03-20-2013, 07:40 PM   #3
ole dollor
ole dollor's Avatar
i would also say ign switch ,or starter solenoid , unless you have wires that are shorted together...
ole dollor is offline   Reply With Quote
Old 03-20-2013, 08:36 PM   #4
buckskins4ever
buckskins4ever's Avatar
yep dont think your ignition switch is springing back off of the start position inside the tumbler. definitely grab a new one, not that bad to put in.
buckskins4ever is offline   Reply With Quote
Old 03-20-2013, 10:04 PM   #5
rmmurphy
THANK YOU ALL!!!! towed the truck home and just to see what it would do i tried to start it after about 30 seconds of running the starter engaged on its own. I did check all wires none of them are shorted together. I will get a ign. switch tomorrow.
