1964 C10 2wd lift
Hi I have a 1964 Chevy C10 2wd. Im looking to try to lift it 4''-6''. My goal is to try and avoid doing a 4x4 frame swap. Looking for suggestions and to see if anyone has done it. I have pictures of what it looks like now and a poorly done photoshop version of what im looking to achieve.
Thanks |
Re: 1964 C10 2wd lift
Boy that's a beautiful truck as it sits.
![]() Join Date: Oct 2012
wow looks like you got 4 wheel steering on that bad boy
Thats a nice truck as it is!!
Posted via Mobile Device |
![]() Join Date: Sep 2011
Somebody has put a lot of work into that truck already. I'd suggest you leave it as is.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
Agreed with those above. The truck looks great as it sits. If you're dead set on lifting it, I'd start with a different truck.
There actually was a quad steer in the early 60's. They were used by the military to measure the blast area of bombs. Had a pic somewhere....will try and find it.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
1961 crewcab
check out this build:
http://67-72chevytrucks.com/vboard/s...d.php?t=282398 other than that: my only ideas are a 2-3 inch body lift. then for frame mods: you could put some 2 inch spacers between the front suspension and frame rails, but seems like a lot of work would go into fixing the steering. if it was a leaf spring truck the back would be easy, but since it is a trailing arm style the problem you will have is that the higher up you go the farther forwar the wheel will move... that said if you "flip" the axle you might get 3 inches in the rear...just switch the trailing arm perches to the top of the axle housing, instead of the bottom... also maybe some spacers between the coil springs and the frame.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
![]() Join Date: Jul 2009
I would put a 4x4 frame under it and be done
It's your truck, but as others have stated it looks damn nice as is.
