03-20-2013, 08:56 PM | #1 |
Top of carb broke for stud. FIX?
My 230 has a single barrel rochester carb and the bracket that holds the stud is fine but the carb is broke out where it sets into. Does anyone have a fix for this? If so, what did you do?
03-20-2013, 09:25 PM | #2 |
Re: Top of carb broke for stud. FIX?
Find a parts carb or donor carb......
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
03-20-2013, 11:18 PM | #3 |
Senior Enthusiast
I agree. I'm a JB Weld enthusiast but don't think you'd want to try a repair with any kind of epoxy. Someone that knew what they were doing might be able to solder or braze a repair, but if anything chipped or cracked it would be ingested and at least mess up the carb, if not the engine.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
03-21-2013, 07:51 AM | #4 |
I cannot picture the broken part; but can you go 90-degrees and drill new mounting holes for the bracket?
sam |
03-21-2013, 08:37 AM | #5 |
Ive encountered this several times over the last 20 years. Ive never found any solution to this other than replacing the top of the carb. Tried several different epoxy's when I was younger (which I wouldn't do now as it could fall down the carb if it broke off).
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
