Double Flaring Stainless Steel
Well I tried a cheap tool from autozone and that was a waste of time. Has anybody had good luck with a flaring tool for stainless steel? I was looking at Ridgid 345 kit for about 120 dollars. If anybody has any good reviews on flaring tools I would appreciate it.
Thanks Gary
My 1970 C10 Build "Project Teacher" |
![]() Join Date: Apr 2012
Re: Double Flaring Stainless Steel
Check out the one sold by eastwood. They are pricey but worth it.
Posted via Mobile Device |
It will need to be a hydraulic flaring tool. Yes, they are available. Bring your wallet.
The Eastwood is not hydraulic
I watched the video at eastwoods and it looked like it did it easily. The reviews looked great, several people said they used it on stainless. It looks like its the real deal. I hate to spend that much for a couple of pieces, but I guess it will be there the next time I need it.
![]() Thanks
Why do you need stainless? Just for being pretty of for the non-rust? If rust is the issue, there are far cheaper solutions. I've been using the Ni-Co alloy tube for several years. It does not rust and looks like copper.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
I used a Snap-On double flaring tool for my stainless lines. The 3/8 bits break easily so be careful but it worked great. I broke 1 on all of my brake lines.
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 1972 Chevy SWB Highlander OLIVE Build thread coming |
theres a few things you can do to help buy a good tool is the best option i tried the jegs and ruined it i had another that barely survived but a big problem with stainless is it work hardens so if you use a tubing cutter it will create a very hard end that will not flare or it will split apart so use a saw to cut it and make sure its straight or you will break your dies
My Patinia'd 69 69-http://67-72chevytrucks.com/vboard/showthread.php?t=517537 My RHD 68 http://67-72chevytrucks.com/vboard/s...d.php?t=594928 |
^^ this. If just going for a rust-free solution the NiCopp lines are the way to go. So easy to bend & flare it's almost silly. And I use the Ridgid 345 kit by the way.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
Thanks guys for the info, I wanted stainless for the look. I went ahead and placed an order with Eastwood for there professional flaring tool. It was more than I wanted to spend, but if it works I'll be happy.
#11 | |
2WD Jimmy
![]() Join Date: Mar 2005
![]() Quote:
Good choice. I feel the same way about it.kinda pricey for the limited times I'm going to use it but I know it's there if I need it. And you know the job is done right. Last thing you want is the lines to leak all over your freshly painted/powdered frame.
I ordered the SnapOn tube bender as it also seems to be the tool of choice by many. It works great. I thought of buying the flaring tool and renting it out to other members for a small fee. Posted via Mobile Device |
#13 | ||
I find it best to saw the line, file it flat/smooth, de-burr, lubricate, and be sure to blow out any shavings before installing. Quality annealed line helps too.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#14 |
^^^ Good job re-posting that. Regular steel line work hardens as well. I often use a saw instead of cutter, and am not beyond annealing my newly made double flares with a torch to ease proper seating upon installation.
#15 |
Just wanted to give an update, Tom was correct. This tool from Eastwood is the bomb! It flared the stainless steel lines like butter. It was on sale for 200 witch is still alot, but glad it's in my collection now. If anybody's looking for a flaring tool, I strongly recommend.
Thanks for all the help Posted via Mobile Device
#16 |
Told ya!!
