Old 03-20-2013, 10:13 PM   #1
mrsmothers
I have a gremlin
So side marker light wont light up. put a new bulb in it and nothing. tested to see if I was getting power, powers fine took a bulb out of one of the others and put it in the dead one and nothing. So I need some words of wisdom because I am stumped
mrsmothers is offline   Reply With Quote
Old 03-20-2013, 10:30 PM   #2
Mister-B
Re: I have a gremlin
Do you have a rusted rocker panel on that side? I think the wires travel right under the rocker panel. Could be that the jagged rust has cut a wire.
Another thought, could be that the market light itself has issues. Maybe corrosion or something. Try installing the one from the other side to see if that works
Mister-B is offline   Reply With Quote
Old 03-21-2013, 12:10 AM   #3
Aaron Burkemper
Aaron Burkemper's Avatar
If you have power but it doesn't work, check your ground connection. My right front marker does that, and its a cruddy ground.
1971 C20 "Shreck"
1980 C30 dump bed "Ratchett"
Aaron Burkemper is offline   Reply With Quote
Old 03-21-2013, 12:16 AM   #4
SS Tim
SS Tim's Avatar
Ground would be the place to start if you have power and a know good bulb. What year is your truck and is it a front or rear?
SS Tim is offline   Reply With Quote
Old 03-21-2013, 12:25 AM   #5
rattle69
rattle69's Avatar
yep ground! check continuity to body from light ground, easy fix
rattle69 is offline   Reply With Quote
Old 03-21-2013, 12:27 AM   #6
buckskins4ever
buckskins4ever's Avatar
I agree man......check the ground wire from behind marker....if it looks ok there........try grounding it to the fender by hand just to double check it. you can always splice into a ground wire with no issues.
buckskins4ever is offline   Reply With Quote
Old 03-21-2013, 12:35 AM   #7
Gumby
Gumby's Avatar
get a gremlin bell, problem solved
[that is a real thing ^ ]
Gumby is offline   Reply With Quote
Old 03-21-2013, 12:39 AM   #8
buckskins4ever
Thumbs up Re: I have a gremlin
No Gumby.....he needs Bright lights.....that kills all gremlins
Old 03-21-2013, 12:48 AM   #9
Gumby
Gumby's Avatar
check all your bulbs really well, front back, side to side, GM does some daisy chain wiring that can act funny.
had my left front turn signal go funky on my 86 bird, was to a point I just wired around it to make it work. ended up being one of the many marker lights in the tail goofing it up. making it act like a bad ground as it had power.
Old 03-21-2013, 07:04 AM   #10
cdowns
cdowns's Avatar
gremlins are cool
Old 03-21-2013, 07:16 AM   #11
Bluechevy68
Bluechevy68's Avatar
as stated above check ground. My 68 did the same thing and it was the ground connection.
Bluechevy68 is offline   Reply With Quote
Old 03-21-2013, 12:32 PM   #12
Lattimer
Lattimer's Avatar
Mine did this on both marker lights on the passenger side. Turned out the socket was so loose the bulb wasn't making contact. Test light showed fine, but bulb wouldn't light. I spliced in 2 new sockets (they have them at any parts store) and it works fine now.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 03-21-2013, 11:35 PM   #13
mrsmothers
its the pass side marker where is the grounding strap located. and yes gremlins are cool thats the only car I would trade my truck for.
