Old 03-20-2013, 10:29 PM   #1
walkerscott
Battery relocation options
I am looking to relocate my battery from under hood to some other location
Any pictures of suggestions Thanks
walkerscott is offline   Reply With Quote
Old 03-21-2013, 01:35 AM   #2
andrewmp6
Re: Battery relocation options
If you run a sealed battery you can put it just about anywhere you got room.If you have a single gas tank or removed the factory tanks for a rear tank you got a lot of frame rail to use.
andrewmp6 is offline   Reply With Quote
Old 03-21-2013, 01:42 AM   #3
zaccaglin
zaccaglin's Avatar
With some long thick gauged wire, you can put it anywhere.
In my dodge i had a second battery that kept my accessories, horns, and compressors from draining the main located in my toolbox that was mounted in the bed. Took me and afternoon to do. Used some #2 wire, and for the positive, and #0 from ground to frame. Worked out great.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 03-21-2013, 03:35 AM   #4
bigwheel15
bigwheel15's Avatar
A drop down battery box would be an easy way to move your battery and still have easy access to it if need be.
bigwheel15 is offline   Reply With Quote
Old 03-21-2013, 06:22 AM   #5
wraprail
wraprail's Avatar
stock battery tray relocated under bed. #2 cable run to ford solenoid at firewall. Disconnect switch on ground cable.
wraprail is offline   Reply With Quote
Old 03-21-2013, 08:49 AM   #6
walkerscott
Bigwheel15
I would like to see a picture of your truck
I love yellow and orange on our trucks
How does the drop down box work ?
Looks like you need plenty of slack on the cable because the terminal may be difficult to remove with the box in the upper position
Old 03-21-2013, 08:50 AM   #7
walkerscott
wraprail
Just curious why would you prefer the disconnect on the negative it should make any difference the circuit is broken either way.
Good thought on the ford solenoid
Old 03-22-2013, 12:26 AM   #8
wraprail
wraprail's Avatar
Ground was there and easy and worked out good. I don't have easy access to battery with bed on so the disconnect is just for service ect.
