03-21-2013, 01:11 AM | #1 |
Where to buy bench seat hog rings and pliers?
When I ordered my seat cover, it didn't dawn on me that I'd need hog rings and pliers. They sell both at Brothers for a good price, but at this point shipping would cost more than the kit, and it would be a while before it gets here.
I've checked Home Depot, but theirs is for chain linked fences. Checked Harbor Freight, but they only carry the pliers. Is there a brick and mortar store you know of that carries these? Posted via Mobile Device |
03-21-2013, 01:17 AM | #2 |
The Older Generation
Re: Where to buy bench seat hog rings and pliers?
My local tractor supply carries them. I don't know if you have any kind of a farm store near you or not. If you do give them a call. LockDoc
03-21-2013, 01:19 AM | #3 |
O'Reilly, Autozone
03-21-2013, 01:22 AM | #4 | |
That's a great idea though. Hadn't thought of that. Is there just a standard type ring I can ask them if they have? Posted via Mobile Device |
03-21-2013, 01:39 AM | #5 | |
All I know them by is hog rings. What is different about the fencing rings? LockDoc
03-21-2013, 01:50 AM | #6 |
Call an upholstery place and ask if they have an extra set and some rings they might sell ya.....or at least tell you where to get the right ones.
03-21-2013, 01:51 AM | #7 | |
This is a pic of the ones from Home Depot. Will that work? Posted via Mobile Device |
03-21-2013, 01:53 AM | #8 |
Fence rings are larger and heavier wire. Automotive rings tend to be sharper as well. Try finding a on-line auto trim supplier. Good pliers are a must, cheap pliers are an absolute pita. If you want, email any item specific links for on-line or ebay and I'll take a look at them.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
03-21-2013, 01:54 AM | #9 | |
Yep.
03-21-2013, 01:55 AM | #10 |
try an auto uphostry supply or any of the larger craft stores (joann fabrics)
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
03-21-2013, 02:03 AM | #11 | |
http://www.harborfreight.com/straigh...iers-3102.html Would these rings work? http://www.homedepot.com/p/Prime-Lin...6#.UUqim-69KSN Posted via Mobile Device |
03-21-2013, 02:08 AM | #12 |
The Home Depot fence rings will not even fit in my automotive ring pliers. They are a heavier gauge wire than the automotive rings but I still ended up at a fence supply for rings that were bigger and a heavier wire (about 50%) for my dog anti-dig panels.
For automotive work you want a quality sharp ring that will close fairly easy with the ends passing not butting as it goes round.
03-21-2013, 02:18 AM | #13 | |
03-21-2013, 02:37 AM | #14 | |
The pliers might work. They may be too big at the tip end. The spring is a big help too. I'd buy some rings and run by HF to try a pair if they stock them. If they close the ring down to a round pencil size you are good to go. However the tips might need grinding, back toward the cups, to get into tight spots. Most pro pliers have a real high taper to make tips as small as possible. So forget any of the cast metal type pliers you see with a 1/8th or so flat ledge around the tip cups.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 03-21-2013 at 02:40 AM. Reason: My editor fell asleep |
03-21-2013, 02:45 AM | #15 | |
03-21-2013, 02:58 AM | #16 |
How did we end up without a Husky picture in a Mister-B thread?
Here are two of my spell check/editor/research assistants tonight.
03-21-2013, 03:02 AM | #17 |
A budy of mine needed some and went in to an upholstery shop and the guy gave him a bag for free. I would check an upholstery shop first for supplies, may not have pliers, but they should have plenty of the rings.
03-21-2013, 03:08 AM | #18 |
Did a little checking and found some KD pliers at amazon. The first link is for 3702 straight handle pliers and they also have a 3704 bent handle plus 3702 a set of both. Straight or bent is a matter of preference and working space (like under a progressive cover installation). Straight would be my default, if you need the excuse the set will cover about everything.
KD Tools 3703 Straight Hog Ring Pliers -... KD Tools 3702 2 Piece Hog Ring Plier Set -...
03-21-2013, 03:12 AM | #19 | |
Great looking dogs, by the way Posted via Mobile Device |
03-21-2013, 08:01 AM | #20 |
Where did you get your seat covers? Did you also get new foam? I am in need of a complete overhaul of my seats and am about to give it a go.
Thanks...Rick '72 Blazer 4x4 |
03-21-2013, 09:58 AM | #21 | |
My foam seems fine, but when I start replacing the cover, if it needs foam or springs, I'll go to the junk yard for that Posted via Mobile Device |
03-21-2013, 11:10 AM | #22 |
I just go to my upholstery guy and he'll get me anything I need. I've never had him get my tools but I'm sure he'd get them
03-21-2013, 11:16 AM | #23 |
Larry Dennis Company in Fort Worth Texas has it all. It is a textile compnay and they ship all over. I used to work there almost 20 years ago and still buy from them when I need something.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new. 66 GMC Short Step, 84 Front Suspension, many more mods to come 67 Chevy 3/4 Ton, 327, Auto, Factory A/C Ya must have been movin cause I was haulin a*$ when I passed you |
03-21-2013, 02:34 PM | #24 |
Brothers really pulled through, and did a nice touch with my order. Unbeknownst to me, they put a pack of hog rings and some pliers in the box with my seat covers that just got delivered!
03-21-2013, 04:32 PM | #25 |
Mark and the guys over in Corona do a great job. You can't ask for a higher quality part or better customer service.
