03-21-2013, 02:56 AM | #1 |
What grills can I use with this support?
I can't seem to get a straight answer on this, what grills can i use with this rad support? If you got pics of my options, even better.
It looks to me like if you cut off the inner light brackets, it would be just like earlier supports? |
03-21-2013, 09:16 AM | #2 |
Re: What grills can I use with this support?
Any gmc grill 67-72 will fit, and I have heard rumors that if you remove the gmc buckets and add some holes to hold the headlight buckets that it will take a 67-68 chevy grill. I have never tried this, but I have heard it from more than one person.
edit; I found a link where a member says he did this and it works. Look at post #5 http://67-72chevytrucks.com/vboard/s...d.php?t=143068 Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Last edited by raggedjim; 03-21-2013 at 09:49 AM. Reason: new info added |
03-22-2013, 02:19 AM | #3 |
So I was onto something. Looks like the grills Im after, will work, with very little modifications. Perfect! thanks for the link!
