Old 03-21-2013, 12:25 PM   #1
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
flex plate troubles.
So lately my truck has not been having luck with starters. burned one up,grinds etc. yesterday i jumped into the old beast and when i went to start it it made a girding noise. but started. went to pay some bills came out and the starter did it's thing but sounded like it wasn't "meshing" to the flex plate after 5-7 trys finally cought and i brought it home and parked it, only thing i can come up with is my flex plat is frigged. the starter is a brand new high torque with off set mounting holes.
someone please help loosing my mind with this.
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 03-21-2013, 01:20 PM   #2
rollin thunder
rollin thunder's Avatar
Re: flex plate troubles.
I had a buddy who had a very similar problem as to what your describing and what he described and he had some broken teeth on the flexplate. new flexplate and bam like magic. haha but For the record I didnt hear the truck for myself this is just what he told me.
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373
1984 Chevy C10 short bed
2001 Chevy Impala police cruiser
2001 Chevy Silverado 1500 Z71 4wd extended cab dd
rollin thunder is offline   Reply With Quote
Old 03-21-2013, 01:47 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
When i got the 78 it was,a "crunchy" to start
replaced starter,didn't help
realized the flywheel looked worn(not all the way around,maybe 3 evenly spaced out areas)
didn't know how bad till out ,and compared to a new one
no shims
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-21-2013, 01:54 PM   #4
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
no shims
how much is a new one or do i want to know?
Old 03-21-2013, 05:05 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
i think it was about $80
John
Old 03-27-2013, 02:46 PM   #6
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
my ring gear is 140 tooth (or at least that's what i counted) does this sound right? thought one was 153 and one was 168?
Old 03-27-2013, 04:47 PM   #7
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
from what i have researched since i have a off set starter bolts my truck should have the 168 tooth ring gear. :S
Old 03-27-2013, 08:43 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
that's what I have too
John
Old 03-27-2013, 09:11 PM   #9
Skunksmash
Skunksmash's Avatar
Isn't there some kind of flex plate upgrade he can do? Might think about that while you're already in there.
Skunksmash is offline   Reply With Quote
Old 03-27-2013, 09:33 PM   #10
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
you just ordered the 168 tooth and all was well?
Old 03-27-2013, 09:33 PM   #11
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
that would be great if there was.
Old 03-28-2013, 05:20 AM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
yup
John
Old 03-28-2013, 05:55 AM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
yup
yup
John
Old 03-28-2013, 11:46 AM   #14
88Jimmy4x4
88Jimmy4x4's Avatar
Take the inspection cover off and check the teeth, you may just need to shim the starter
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 03-28-2013, 12:06 PM   #15
Skunksmash
Skunksmash's Avatar
http://www.csr-performance.com/shop/...num-flexplates
Don't know how much you would gain out of it though. I assume lighter would mean less rotating mass so you might gain a smidgeon of power and MPG. Its probably better considered as part of a whole system like with an aluminum driveshaft and lighter aluminum wheels etc etc.
