03-21-2013, 02:01 PM | #1 |
GL5 in sm465 and HO72
Hello all:
I just nursed home a 2WD 69' C20 fleetside with a 292 and sm465. She is just what I have been looking for. The truck is straight (rockers aren't even -that- bad) and relatively untouched. The first order of business is a tune-up and changing out all fluids. Most of my time is spent in the Willys realm with flatfender CJs. You are always warned about putting any 80w90 gear oil in the old T90s with any kind of additives, GL4, GL5, etc.....Apparently the additives eat away @ the brass synchros, blocking rings, etc. I don't know much about the SM465 other than its solid reputation. Is it OK to use modern (GL5) 80w90 gear oil in the SM465 and HO72? What do you all use? Thanks in advance. Pics soon to follow. |
03-21-2013, 02:45 PM | #2 |
Re: GL5 in sm465 and HO72
GL5 not sure about, but in any case manuals are always good to have. You can download many here.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
03-21-2013, 03:08 PM | #3 |
I looked in my 1972 factory service manual. It specifies GL-5 in both the SM465 and the rear axle. It says to use straight SAE 80 in trans unless temps are continuously above 32 degrees F. Axle SAE 90. Straight 80 or 90 is harder to find around here so I would say you should be OK with 80w-90 in both.
03-21-2013, 11:25 PM | #4 | |
Cluster King
