Tank relocation Question
I am seriously thinking of going w/ a Boyd tank. I thought about it but didn't have it in the budget when I put the A/C in. Now that the windows are up and the smell of gas is irritating me. The sting of purchasing the A/C is fading and a tank relocation might be on the horizon; but I have a question -
For those have done this and wanted to maintain the stock tank look or didn't want to have to deal with the body work of filling the tank neck hole - is there a way to fabricate a dummy neck and still gain the space behind the seat? TIA |
![]() Join Date: Oct 2010
Re: Tank relocation Question
You could cut the neck of of a stock tank fab a bracket on the inside to hold it. Put the cap on and nobody would ever know. Shouldn't be that hard to do.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
Unless you you ave a leaky tank you can solve the gas smell for a few bucks and about an 30 minutes. Just replace the rubber hose connecting the lines.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
That antenna set-up is very slick! I'm stashing a stereo in the glove box, and I considered some sort of hidden antenna, but this is even better, as a tank removal is in the cards, too. Sure am glad I took a look!
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
When I did the tank relocation on my stepside I just cut the neck off and put a nice cap on. I pushed it down to where the cap was down on the grommet. Looked nice I thought.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
