03-21-2013, 05:13 PM | #1 |
4 bolt or 2 Bolt
I found this on craigslist here locally, I'm thinking about maybe trying to get it but I wanted to know the ways to tell a 4 bolt main to a 4 bolt main here's the link to it. I want to check the vin to check but I dont know how.
http://houston.craigslist.org/pts/3606605113.html thanks for the help guys
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
03-21-2013, 05:25 PM | #2 |
Re: 4 bolt or 2 Bolt
500hp go for four bolt. Under that the two bolt is fine.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
03-21-2013, 05:29 PM | #3 |
I wanted to do a 383 stroker for my truck, should I have a 4 bolt for that?
03-21-2013, 05:47 PM | #4 |
You can tell from the pictures that it is a 4 bolt main block. I would have no issues pushing a studded main 2 bolt into the 400 to 500hp range, but for anything over that you should be using an aftermarket block anyways.
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
03-21-2013, 05:52 PM | #5 |
Okay, see I didn't know how to tell the difference between them, or how to tell the difference I looked up the vin on it and it showed that it could be a 2 or 4 bolt and I figured someone here could help me out better.
03-21-2013, 06:16 PM | #6 |
Look at the main bearing caps. (The three center pieces) It has 4 bolts. A 2 bolt main will only have 2 bolts.
Trevor 74 C20...work in progress. 04 Saturn Ion...Daily Driver |
03-21-2013, 06:21 PM | #7 |
Okay I see it, so what would I need to pull off on my motor to find out if my current motor is a 2 or 4 bolt?
03-21-2013, 06:40 PM | #8 |
Oil pan
1979 Sierra Classic Heavy-half 1996 Silverado x-cab "the daily" |
03-21-2013, 06:45 PM | #9 |
And I'll just look for those same like 3 bolts or what?
03-21-2013, 06:49 PM | #10 |
Look for four bolts on top of the main bearing caps tlawre87 said.
EDIT: I saw you other thread about pitting a cam in a 305. Is the motor you trying to figure out the the main bolt number a 305 or 350? Most 305 are two bolt. There are some rare 4 bolt 305s though according to some people.
1979 Sierra Classic Heavy-half 1996 Silverado x-cab "the daily" Last edited by GM-power; 03-21-2013 at 06:56 PM. |
03-21-2013, 06:51 PM | #11 |
Alright thanks for all the replies guys!! I'm going to look into it pretty soon, can I do it with the motor still in the truck or do I need to have the motor out?
03-21-2013, 07:02 PM | #12 |
It can be done without pulling the motor, but you may have to loft the motor up a bit and you might not have to. Not much help but thats just the way it goes sometimes haha.
03-21-2013, 07:03 PM | #13 |
I have seen several 2 bolts pushed to 600hp and I'd take a splayed 2 bolt over a for bolt any day. I always thought that was a funny subject. But to the subject question yes it's a 4 bolt which for a street motor is irrelevant. But if you plan to do something with this where you get something extra is the fact that that block is a high nickel/high tin content. Just my .02
Posted via Mobile Device |
03-21-2013, 07:03 PM | #14 |
Haha I understand thanks for all the help and advice it's greatly greatly appreciated!
03-21-2013, 07:07 PM | #15 | |
Okay but these 2 bolts are they splayed like you mentioned or are they actually just the 2 bolts? My truck is mainly going to be for show and to pull my boat, but if I can push good power out of a 2 bolt I'll just keep the 2 bolt in there Posted via Mobile Device
03-21-2013, 07:14 PM | #16 |
Just a 2bolt, and if you are not building a 500+ high rpm race motor than a 2 bolt will do any show or boat pulling you plan to do.
03-21-2013, 07:18 PM | #17 |
Yeah, I'm just going to try and build a really good bottom end and have good torque and just let the HP follow it. If I want splay it, where can I get that done?
03-21-2013, 09:30 PM | #18 |
Just google splayed main caps and which ever one you decide on just take them with the motor to who have do the machine work and they can install them or you can purchase from any machine shop.
03-21-2013, 09:44 PM | #19 |
Alright awesome!! Thanks for all the answers I appreciate it a lot
