03-21-2013, 06:56 PM | #1 |
Bed height Issue
I am in the process of trying to make all the sheet metal on my truck fit right. Took a while to get all the front sheet metal right - thought the battle was over, until I set the bed back on the truck. The bed sits about 3/4 inch higher than it should, and this is with NO spacers of any kind. I do have about 3/4 inch between the frame and bed where the frame arches for the rear end - but it is sitting flush on the mounts. Any suggestions on how to correct this?
03-21-2013, 07:15 PM | #2 |
Re: Bed height Issue
Assume you used a new cab mount kit. Did you reuse the thick washers you took off with the original set? The new sets do not come with the thick washers that originally came on these trucks. Another thought, you didn't over torque the cab mounts compressing the cushions to much?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
03-21-2013, 07:35 PM | #3 |
Is your bed sitting the same on both sides im having the same prob only on one side
Posted via Mobile Device |
03-21-2013, 07:47 PM | #4 | |
Cluster King
Remember the bed is fixed mounted with no rubber and the only thing that changes it is frame twist. |
03-21-2013, 08:41 PM | #5 |
The order of mounting should be the bed and cab, and then the front sheet metal. That way you don't have an issue with the bed being too high.
03-21-2013, 09:20 PM | #6 |
Thanks for the input. I didnt use the old washers - so Im sure thats part of it. I also did the cab, then the front sheet metal, and now the bed - so Im sure that didnt help either. I think I will start with finding those thick washers and see if that fixes the issue. Thanks for the input!!
03-21-2013, 09:31 PM | #7 |
Do you have the factory service manual?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
