03-21-2013, 07:34 PM | #1 |
4X4 Engine Crossmember Upgrade
EDIT: I HAVE ANOTHER ONE AVAILABLE AS OF JULY 6th! Now that you have upgraded your front end with a sway bar, its time to upgrade your engine mounts so you don't snap the motor mounts when you go 4 wheeling. This one has the more reliable clam shell setup. You will need to get new rubber and some grade 8 bolts.
$50 plus shipping for the crossmember and motor towers. Shipping should be under $30. $20 for a pair of clam shells if you need them. Post office money order or paypal (you cover fees) Thanks, Ray Last edited by KrazyRay; 07-07-2013 at 11:54 AM. |
03-21-2013, 09:33 PM | #2 |
Re: 4X4 Engine Crossmember Upgrade
what year truck is this from? thanks
03-21-2013, 10:28 PM | #3 |
Its from an 87.
03-22-2013, 05:19 PM | #4 |
"Trucks with Class"
That is very interesting. Does it place the engine in the same stock location? Do you have any pics of one installed? thanks for good info...frank
03-22-2013, 07:16 PM | #5 |
I don't have any pics, but I saw it on a truck a couple of years ago. I know the crossmember lengths are the same and I will need to check to see if any mods are needed for the towers.
05-18-2013, 09:39 PM | #6 |
Did you ever get around to checking the fit on this????
05-18-2013, 10:11 PM | #7 |
got my attn. too. bolt in or rivet? is it bolt in the way pictured?
website https://www.villagegarage.com/ truck guy in the whiskey world https://www.instagram.com/c10glen/?hl=en https://www.hemmings.com/stories/car...e-perfect-day/ |
05-19-2013, 12:59 AM | #8 |
It looks like the engine towers have to be shaved down a bit to fit 67-72 frames. It does not look like it would be a tough mod. The crossmember was originally riveted to the frame and the towers were bolted. Most of the time the rivets are replaced with grade 8 bolts.
05-19-2013, 01:23 AM | #9 |
pm sent thanks. glen
07-07-2013, 12:04 PM | #10 |
Here's another one:
