Old 03-21-2013, 10:07 PM   #1
six8burban
No fuel pressure @ fuel rail
I have no pressure @ fuel rail, dropped gas tank and connected pump to battery and it spends and sounds fine. Truck started without trans a couple of weeks ago and now that I have put it back in it won't turn over. Fuel filter and entire fuel system is new but has been sitting for about 7 years without any fuel in system. What else is there for me to check?
.....might I add that I thought tank needed more fuel so when adding fuel it was getting stuck in filler neck? Waited 15 min and gas was sitting there and I could hear it dripping into tank. I squeezed filler neck and fuel went down only as I continuously squeezed? Dropped tank inspected filler neck and tank nothing seem to be clogged?
six8burban is offline   Reply With Quote
Old 03-21-2013, 10:35 PM   #2
ls1nova71
ls1nova71's Avatar
Re: No fuel pressure @ fuel rail
If you dropped the tank and powered up the pump and you can hear it running but you're not getting any pressure, it sounds like your hose between the pump and sender either blew off or has a good size hole blown in it. You'll have to pull the sender and check.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-21-2013, 11:08 PM   #3
six8burban
...the small hose in this pic? looks good.
Old 03-21-2013, 11:13 PM   #4
six8burban
fuel tank wiring
Old 03-22-2013, 02:22 AM   #5
rcrahn
rcrahn's Avatar
Check the tank vent. When putting liquid in or taking liquid out a vessel you need a clear vent.
rcrahn is offline   Reply With Quote
Old 03-22-2013, 08:06 AM   #6
six8burban
I have no vent....see pic, am I supposed to have one for gen 3 motor
Old 03-22-2013, 09:56 AM   #7
bohmankid
bohmankid's Avatar
we probly need more info. are you checking the fuel pressure with a gage? you said the motor isn't turning over at all (not a fuel problem)? does the fuel pump turn on when you turn the key? have somebody in the truck turn the ignition on while you stand next to the tank to listen to the fuel pump to see if it primes.
bohmankid is offline   Reply With Quote
Old 03-22-2013, 10:19 AM   #8
six8burban
Yes I'm useing fuel gage@ fuel rail. Yes fuel pump turns on by key. Yes I can hear pump come on. Motor fires with starting fluid
Old 03-22-2013, 10:51 AM   #9
Wasted Income
Boosted Member
Wasted Income's Avatar
What regulator are you using? If it's one of those junk corvette regulator/filters, that might be your problem. I have had 2 that were bad right out of the box.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 03-22-2013, 11:03 AM   #10
six8burban
[QUOTE=Wasted Income;5963460]What regulator are you using? If it's one of those junk corvette regulator/filters, that might be your problem. I have had 2 that were bad right out of the box.[/QUOTE
Regulator? If we are thinking the same thing then It's the stock regulator, I never changed it.
Old 03-22-2013, 11:35 AM   #11
Wasted Income
Boosted Member
So I take it you're using the truck rails, with the regulator built in?
Turbo diesel
Old 03-22-2013, 12:47 PM   #12
bohmankid
bohmankid's Avatar
The fuel gage reads 0? I'd check the lines for blockage at that point. How new is the pump? I'm guessing the regulator in line after the fuel gage and isn't the problem, if you have the older motor with the regulator built in then.
Old 03-22-2013, 02:59 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You DO need a vent by the way. Normally it would trigger an emissions CEL but since emissions is usually deleted in a swap, it will just have random fuel hiccups/fill issues/stalling/boggin.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-22-2013, 03:48 PM   #14
six8burban
Can I just use a Vented gas cap?
Old 03-22-2013, 10:45 PM   #15
arider278j
Another poss is fuel line pinched between trans and motor. You said it ran before trans was installed. Just a thought
arider278j is offline   Reply With Quote
Old 03-22-2013, 11:30 PM   #16
solidaxel
solidaxel's Avatar
Disconnect the fitting (first connection) after the
tank (pump) and see if you have fuel and pressure.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-23-2013, 02:50 PM   #17
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Sure can, anything is better than no vent. Mine only vents through the cap.
Old 03-23-2013, 07:35 PM   #18
whitels1
whitels1's Avatar
Mine vents through the cap also but on hot days and heated by the exhaust, there is some serious pressure in the tank, I'm in the process of hooking up the evap/purge to the ls stock status, but so far no drivability issues.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 03-26-2013, 10:57 PM   #19
six8burban
Bad ground! Yup bad ground from engine to frame.....problem solved....thanks guys!
