![]() Join Date: Jan 2012
Subs under the seat
Anyone done the homework on the size needed to stick some subs under a bench seat? Fairly certain I can make the enclosure, but am trying to cheat a bit before removing the seat or cracking my neck trying to measure that area...
'68 Longbed Stepper. Mango Tango |
Re: Subs under the seat
For some trucks, there are already pre-fabbed ones out there & almost so cheap that is is hardly worth the cost savings to build it yourself unless you really have the way to bring the wood homes, buy the upholstery, time & tools to build one.
I do like building my own stuff buy also realize sometimes the slightly higher cost of pre-fabbed is worth it.
2001 Yukon Factory Grey Metallic~2" DJM Key front drop/3" DJM Rear Springs~stock 16" chrome steel wheels~5.3/4L60E~Volante CAI w/under bumper air scoop~Magnaflow 10426 Bullet muffler~DDM LED all exterior lighting/55w-5000k HID Hi/Low/35w Fog
I am all for doing it yourself, but I agree there are some nice pre fabs. It depends on what sub(s) you want to run and how you want it set up.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
I just built a box under the passenger side of my bench seat. In a faily simple box .25 cu/ft is about all your gonna get per side with 3/4 mdf. You could probably get .30 or so with a more complicated box.
Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=534956 |
I think I have some measurements around here somewhere, but building it yourself is definitely the way to go. The springs that pull the seat forward take up some space as does the wire/rod that connects the two sides. If you don't adjust your seat you can get a bit more space out of it by taking those two things completely out. I'd go with two shallow mount 10" subs in your case. There's a bit of room height wise under there so I decided to go with a pair of 6.5" speakers and the small 6.5" JL subwoofers. They're tiny but they pack a pretty good punch.
I'd look at these: http://www.sonicelectronix.com/item_...e-SWR-T10.html http://www.sonicelectronix.com/item_...-P3SD4-10.html http://www.sonicelectronix.com/item_...a-SMAX124.html
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
I used to have two 10" earthquakes under my seat. The box was a little small for those speakers though & I think 8"s would of been a better choice. Like posted earlier I think the boxes I made were around .25-.30cu.ft. & I had to remove the rod that connects to both sides for seat adjustment. I made the top one piece so it gave me a place to mount the amp above the hot floorboard. [__]___[__] <This is kind of what it looks but upside down(hopefully that makes sense).
Overkill is an often underrated achievment Last edited by scrappy; 03-23-2013 at 12:15 PM. |
I used one of the alpine swrt-10 that billett recommended pushed by a fosgate power 1000. Its real punchy and is alot louder than you would think 1 10" would be but even with polyfill it has a hard time going low.
here is mine!two shallow twelves
thanks Cori, that was what I was needing. A picture is worth alot. I have a good friend that is a police officer in Yucaipa. Have visited with him a few times there in your fine city...
Im running one twelve under the passenger side of mine, shallow of course, and it pounds very well. the box is probably 14'x12x8
| Bookmarks |
