03-22-2013, 04:24 PM | #1 |
Control arm shaft centering tolerances
So i installed new bushings and shafts in my upper control arms and as far as the shafts being centered, one control arm was off .070" and the other was .072" off center. what i did was indicate each shaft hole and used an edge finder and bumped up to the side of the arm. Is this something to be concerned about? I really dont want to take these apart again.
03-22-2013, 04:40 PM | #2 | |
Re: Control arm shaft centering tolerances
If it is only .072" and .070" you should not worry about it. That's probably a tighter tolerance than 99% of them came with from the factory. Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
03-22-2013, 04:46 PM | #3 |
yea that's correct .070 thousandths, thanks for answer I appreciate it.
03-22-2013, 05:18 PM | #4 | |
Nate
