Ok, decided to work on my truck today after...I really can't remember.
Anyway, I start it up and it won't turn without serious force as if trying to turn the wheel with it not running. I check the new p/s pump and it is bone dry, so I added fluid to the pump and it still won't turn easy. And the fluid comes right back out. None of the p/s lines are leaking. The p/s gearbox has always had a small leak, but always worked fine. I look under the truck and there's a huge spot of p/s fluid? What's really going on here? Is the box total trash now? How much fluid does the gearbox need to work? And as always many thanks. http://i1294.photobucket.com/albums/...ps9ca6b278.jpg http://i1294.photobucket.com/albums/...psb02c8ebd.jpg Is this missing gasket really important? http://i1294.photobucket.com/albums/...ps370ec868.jpg 1984 10 305v8/th350 Posted via Mobile Device
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
Re: No turning>gearbox>pix
C'mon guys, no advice?
Jack the front tires off the ground, see if you can turn them w/o he weight of the truck on them? Once you get them to turn it will take a few pints to " fill " the system. And the gasket is a seal to seal out grime from getting in to your pitman arm.
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great 1979 Chevy 1/2 ton long bed diesel 1974 Chevy crew cab short bed 3/4 ton 4x4 project 1991 Chevy suburban 2wd 1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo 1961 Chevy pickup 1/2 ton 2wd 1975 gmc crew cab short bed 2wd |
After you put it up on the stands, Leave the engine off while turning lock to lock. Do that several times. Add fluid, repeat. Once level is up, then start. check it, then set down and try again. Should be good to go.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
Just cut the belt. Been driving like a man for three years now
![]() If your hoses aren't leaking then why is there a big puddle on the ground? Depending on how long it sat to leak that out of your steering box Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
^The leaking is coming from the gearbox as soon as I add fluid.
Is it coming from the top or the shafts? How fast is it coming out?
If it's coming out of the gear box that fast just get a reman unit.
It is running out minutes after pouring it in the pump. Who has the best prices on rebuilt boxes? Any online stores?
#10 | |
![]() Quote:
