Old 03-23-2013, 12:40 AM   #1
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Detent Cable
I think I may be leaking from the connection of the detent cable to the trans.
Can I simply unscrew the screw holding in the bracket (at the trans) and pull the cable and bracket out (and bracket off) just far enough so I can replace the o-ring? Anybody know what size o-ring?
I won't be able to see it, so I'll have to do it by "feel". And I *absolutely* don't know how it connects inside the trans case.
Thanks.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 03-23-2013, 12:53 AM   #2
AustinScott
AustinScott's Avatar
Re: Detent Cable
Trans type?
Cable type? (looks like aftermarket... lokar maybe?)
Scott
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi,
My 68-SWB Photo Build Thread
All my Google Albums
AustinScott is offline   Reply With Quote
Old 03-23-2013, 12:54 AM   #3
magwakeenercew2jh
Re: Detent Cable
Originally Posted by AustinScott View Post
Trans type?
Scott
Yeah. Sorry. Looks like my "edit" didn't make it in...It's a TH350. I don't know what brand the cable is.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 03-23-2013, 01:05 AM   #4
67c10rustbuket
67c10rustbuket's Avatar
Re: Detent Cable
The cable should have an eyelet on that end once you remove the bolt and pull up you will need to disconnect the offset formed rod from the trans. Then replace the O ring or whole cable assembly. I have done a couple but it has been quite some time ago. Here is a pic I found that may help.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
