Negative Camber
i wanted to know what kinda gears came in a 68 3/4 ton 6 cyl 3 on tree?,it does about 3000 at 60 mph,thanks again
Resident Curmudgeon
![]() Join Date: Dec 1999
4:11 would be standard gears for that engine drivetrain. I believe 4:57 could be had but would have been listed as an option on glovebox.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
its all about the +6 inches
4.57 gearing.
Your RPMs sound right on the money too. |
Hmmm, maybe I have it backwards. I know small block is 4.57 standard...I'll have to recheck for the inline motors.
Resident Curmudgeon
It could be me thats bass-ackwards here
Fabricate till you "puke"
Im not sure what the norm, but a couple 3/4 tons I dismantled with Inlines had 4.57 gears. The old longhorn had 4.11s(sb with auto trans) crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Negative Camber
alright thanks guys,i would check the glove box sticker,put the guy i bought it from painted over it many different times so no more sticker
