03-23-2013, 06:12 PM | #1 |
1964-1966 trucks - rear sway bars with coil springs?
Howdy folks, I'm just curious about this and how it sets up on our trucks with the rear coil springs. Do any of you have any experience with this? Have any good links to tech articles or photos? I'm just curious as to how it is setup and works with the coil springs and trailing arms. Thanks. -W |
03-23-2013, 06:54 PM | #2 |
Re: 1964-1966 trucks - rear sway bars with coil springs?
I just installed one from CPP.
Sold the 63 and have a 68 now. 63 SWB C10 LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
03-23-2013, 09:37 PM | #3 |
Ah... it has brackets on the frame rail, then brackets/bolts on the trailing arm itself.
Interesting... Thanks for sharing Trsmotrhed. -W |
03-23-2013, 09:58 PM | #4 | |
03-23-2013, 10:26 PM | #5 |
Would be very interested to hear some feedback on how the CPP bar works for you. I have the same bar, but have only mocked it up prior to stripping off the rear suspension (frame going out to be blasted and painted soon)
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
03-23-2013, 11:23 PM | #6 |
We chased down a rear sway bar from a 84 Camaro (junk yard) and flipped it upside down and backwards to work in our burb...works great and it was cheap!
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
03-24-2013, 12:56 AM | #7 | |
RockTonka - I've read various mentions of using that era of rear sway bar on our trucks, but always wondered exactly how it attached. Thanks for sharing the photos! -W |
03-24-2013, 01:13 AM | #8 | |
That looks great. I didn't know you could use a camaro sway bar. Posted via Mobile Device
03-24-2013, 01:47 AM | #9 |
What is the diameter of the Camaro bar? I found one at the yard but it was very tiny. Did not measure but was less than 1".
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600 |
03-24-2013, 03:09 AM | #10 |
7/8" on the rear swaybar, we have a 1 1/4" bar on the front from a dually...overall it feels very well balanced.
03-24-2013, 09:30 AM | #11 | |
Senior Car Nut
http://www.low69cst.freeservers.com/CamaroBar.htm
Larry Last edited by fleetsidelarry; 03-24-2013 at 09:51 AM. |
03-24-2013, 09:47 AM | #12 |
So what exactly is it supposed to do for the rear? I havent done any reading on this subject yet.
03-24-2013, 09:51 AM | #13 |
I will be installing a 1" Camaro sway bar pretty soon. I will be mounting it underneath the axle instead of on top like RockTonka did. My truck is lowered.
Will come back and post pictures. |
05-01-2013, 04:48 AM | #14 |
Anyone else have anything to share?
-W |
05-01-2013, 07:52 AM | #15 |
Senior Car Nut
Woog, another member whose name I can't think of at the moment (imagine that), used the Camaro bar but moved it so that it attached to the trailing arms and frame sort of like the aftermarket one in the 1st response. I was thinking that the thread was in your faq section, but, again can't remember for sure
should be searchable cause I saw it not long ago (less than a year), I'll see if I can find it after I've had enough coffee edit: losthope may be who I'm thinking of http://67-72chevytrucks.com/vboard/s...4&postcount=76
Larry Last edited by fleetsidelarry; 05-01-2013 at 08:06 AM. |
05-01-2013, 08:40 AM | #16 |
Senior Car Nut
Larry |
05-01-2013, 10:17 AM | #17 |
I just installed the bar from Brothers which is an Addco bar repackaged and is just like the CPP and POL bars. I chose it because they had it on sale for $100. The handling is much improved but I don't like the way it mounts below the trailing arms, makes it kinda stick out like a sore thumb from the side view. I really like the Camaro bar being tucked up above the trailing arms and out of sight.
05-02-2013, 09:20 AM | #18 |
Senior Car Nut
good info, T Smith, thanks
Larry |
05-02-2013, 11:22 AM | #19 |
It's Better With Nitro
I didn't have enough room to run a traditional sway bar, so I used a through-frame torsion bar...plus the tubular housing helped with mounting my fuel tank and electric pump.
05-21-2013, 07:26 PM | #20 |
vin63,
my, what a nice frame you have. -W |
05-21-2013, 08:03 PM | #21 |
Thats the same one I used...i love it ,,and CHEAP. i think i paid 20 bucks
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
09-27-2014, 06:53 AM | #22 |
I wandered into this company site awhile back :
Hotchkis Sport Suspension They have some options for rear anti-sway setups... among other suspension components for our '63-'66 trucks. They also have other options for the later model chevy trucks. Anyone have more information to add to the pile? -W Last edited by Woogeroo; 09-27-2014 at 10:00 PM. |
09-27-2014, 09:07 AM | #23 |
1965 Chevy C10, 2005 4.8L/4l60
Woog, those are some seriously nice options from Hotchkis, I dont know if my budget would allow but they are nice!
I like the Camaro, just for price and it seems to work for those that have it.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-27-2014, 10:48 AM | #24 |
With the Camaro sway bar mounted like Rock Tonka did, I wonder if there is room to snake a pair of tailpipes past it?
I love the idea of using a factory Camaro bar, and the price is almost too cheap to pass on.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
09-27-2014, 09:58 PM | #25 | |
Anything that is safe and works is the sort of thing that I am looking for in this thread. -W |
