![]() Join Date: Oct 2012
12 Bolt Rear End w/3.73
I have both a Narrow (pre '70) and a wide (>'70) 12 bolt 3.73, (sorry no posi), with 6 lug axles.
If you need/want 5 lugs, I recently saw a set on eBay for $40. I have done this and it is about a 10 minute swap! $175 or $325 takes them both, if someone wanted it shipped I can get it on a pallet. Last edited by BAT; 05-05-2013 at 09:29 AM. |
Active Member
![]() Join Date: Aug 2007
Re: 12 Bolt Rear End w/3.73
Interested. Can I get pics. Pm sent with email address
Posted via Mobile Device |
I will take,some tomorrow.
Surely someone can use one of these...
![]() Join Date: Sep 2011
Is this one the narrow housing or the later wide housing?
------------ Scott |
Actually I now have 1 of each, I bought the second one because I was told it had a 4.11 gear in it and it turns out that it too was a 3.73. The narrow one has also been cleaned and painted, the wider one has the original patina.
Any idea what shipping would be to Knoxville TN 37931?
If going to a commercial address assuming no lift gate is needed and based on an approximate weight of 175#s (I would need to actually weigh it), it looks to be around $157. I would be willing to put it on a skid if you wanted to set up your own shipping.
Otherwise, Chicago is beautiful this time of year... take a drive up spend the weekend and do some site seeing ![]() Posted via Mobile Device Posted via Mobile Device |
K I'll be thinking about it, thanks.
ttt
Florida Edition
![]() ![]() Join Date: Oct 2010
Coil or leaf setup on the narrow one?
Should be 56.5" back plate to back plate. Posted via Mobile Device
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Coil spring
#13 |
Florida Edition
Thanks, need a leaf setup.
#14 |
I will sell just the gears for $150 +shipping if someone needs just the guts.
#15 |
ttt
#16 |
ttt
#17 |
I would be interested in one to replace a coil spring Eaton rear in a 69 3/4 ton. I think I was told that the later years would bolt in to my trailing arms. Not sure about the panhard. Would need it shipped to 35244. Send me a pm if you can and let's see if one of these will work.
87 3/4 Burb 454 49 Chev Fleetline Deluxe |
#18 |
PM sent
#19 |
TTT
#20 |
Still available.
#21 |
ttt
#22 |
ttt
#23 |
ttt
