03-23-2013, 07:56 PM | #1 |
dipstick question
I have a Lokar dipstick on my 5.3 Vortec and it read correct with the original oil pan. I just installed a CTS-V oil pan and with the 6 qt oil fill it barely touches the bottom of the dipstick. Anyone else have this problem and a solution?
http://www.hotrodswest.com |
03-24-2013, 05:21 PM | #2 |
meowMEOWmeowMEOW
Re: dipstick question
At the risk of being captain obvious; a longer dipstick.
03-24-2013, 06:12 PM | #3 |
As Captain Obvious said, you need a longer dipstick. Oilpans have specific dipsticks, they're different length, you need the one that matches your pan. Since you have a Lokar, You'll need a new stick.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
03-24-2013, 07:01 PM | #4 |
A longer dipstick yes, but I am looking for a Lokar application or part number. I will be contacting Lokar to see what they have to say.
03-24-2013, 09:38 PM | #5 |
You'll probably just have to tell them you need one about an inch longer than the one you have.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-25-2013, 12:58 PM | #6 |
I called Lokar this morning and discussed my issue. They are sending me a dipstick for a LS-1 and told me that it will probably have to be shortened to match the correct oil level. If any of you have this issue the cable dipstick alone is $9.95 and available direct from Lokar.
