Old 03-23-2013, 08:43 PM   #1
Gmcfolife
Gmcfolife's Avatar
For all you leaf spring guys
I raised my front spring mounts up 2 inches to give me an extra 1" drop. Pretty easy to do and works great. Got the idea from another member but just made it to look alittle more factory.
Gmcfolife is offline   Reply With Quote
Old 03-25-2013, 11:39 AM   #2
made2drag
made2drag's Avatar
Re: For all you leaf spring guys
good idea....did it change your pinion angle alot? any vibrations?
made2drag is offline   Reply With Quote
Old 03-25-2013, 02:36 PM   #3
Gmcfolife
Gmcfolife's Avatar
Haven't got that far yet. I do have a spacer on my trans mount. Will see if that makes a difference.
Old 03-25-2013, 03:39 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I agree, it is a good idea. I wouldn't think that a 1" difference in ride height won't cause a significant change in the pinion angle....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 03-26-2013, 09:58 AM   #5
made2drag
made2drag's Avatar
the drop was 1 inch but the front of the leafsprings were angled up 2 inches, seems that would be a good bit of degree change but it may not be too much. with the trans spacer, it will probably be dead on though....
Old 03-26-2013, 10:02 AM   #6
Gmcfolife
Gmcfolife's Avatar
I purchased the truck with a flip kit installed and the trans spacer. I now have drop leafs, drop shackles and now the front mount raised. Before it drove fine so I'm hoping it will be the same.
Old 03-26-2013, 10:25 AM   #7
Davemotohead
Davemotohead's Avatar
I tried it but got Confused and raised the springs by mistake!
edited by staff
Davemotohead is offline   Reply With Quote
