Old 03-23-2013, 08:42 PM   #1
Gmcfolife
Gmcfolife's Avatar
For all you leaf spring guys
I raised my front spring mounts up 2 inches to give me an extra 1" drop. Pretty easy to do and works great. Got the idea from another member but just made it to look alittle more factory.
Gmcfolife is offline   Reply With Quote
Old 03-23-2013, 08:46 PM   #2
Gmcfolife
Gmcfolife's Avatar
Old 03-23-2013, 09:20 PM   #3
JOJABOY
Re: For all you leaf spring guys
is the rear hangers still the same?
JOJABOY is offline   Reply With Quote
Old 03-23-2013, 09:22 PM   #4
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Looks good.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 03-23-2013, 09:25 PM   #5
Mike C
Mike C's Avatar
EDIT: BTW, you posted this same thread 3 times, you should go back and delete the other two.
What style drop do you have in the back? Just shackles or a flip? I'm going to flip mine and I figure that's about as much drop as I can get without a C-notch. I bought some 1" lowering shackles I might use if I need just a TINY bit more. Nice job on this BTW.
I was contemplating boxing my frame on the inside and then moving the leafs inboard by remounting the factory brackets from left to right and vice versa on the new boxing plates. This would give TONS of clearance and you could mini-tub the bed (mine's a stepside) and this would allow for a BIG tire without narrowing the rear if you work your backspacing correctly.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-23-2013, 09:32 PM   #6
Gmcfolife
Gmcfolife's Avatar
For some reason it posted more than once. How do I delete them? The rear hanger are 1 1/2"drop shackles and have 4" drop springs for a total of 6 1/2" drop.
Old 03-23-2013, 09:33 PM   #7
Gmcfolife
Gmcfolife's Avatar
Sounds like a good idea.
