Old 03-23-2013, 09:51 PM   #1
04 orange
04 orange's Avatar
upholstery??
Im looking for some foam and a cover for a 71 bench seat. Looking online the foam seams to run in about the $400 range and the cover in the $300 range. For the cover that doesnt seam that bad of a price, but for the foam that seams ridiculous!!! Iv never had anything upholstered, and i havent called any shops yet. But what can i expect $$ wise to have a seat done for?? Any info would be great guys!! Thanks!!
04 orange is offline   Reply With Quote
Old 03-23-2013, 10:15 PM   #2
kcsa75
kcsa75's Avatar
Re: upholstery??
Foam is petroleum based which is why it's so expensive. You're best bet might be to get a whole new seat at a salvage yard, even if it's out of a later model truck. Around here, bench seat can be bought for $35-$50. Then you can buy a cover and recover it yourself it take it somewhere. I've never had one done, but I hear all the time you can get a seat re-covered for $250 to $300.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 03-23-2013, 11:15 PM   #3
Mister-B
Re: upholstery??
1. Go to junk yard and find some foam
2. Buy a decent vinyl cover from Brothers for $140
3. Install it yourself (buy good hog ring pliers first) or pay an installer about $100-$200 to install it for you
Mister-B is offline   Reply With Quote
Old 03-24-2013, 01:21 AM   #4
oldschool18
oldschool18's Avatar
Re: upholstery??
to bad you werent closer I just took my bench seat out and I'm not putting it back in.
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 03-24-2013, 06:59 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Re: upholstery??
I would never pay that for a piece of foam!
Yours might not even need new foam. If it's a heavily worn seat, you could just add a layer of carpet padding (1/2") to help firm it back up or if it's damaged such as missing a piece on driver side from a worn hole in upholstery, you could add a piece of foam to fill in the damaged area. I did that with my wrecker project. The driver side material was worn and torn so the foam was missing a bit from all the years of the driver sliding in and out of the truck. I just cut some foam (just some flat box packing material type, nothing special, you might have some lying around) and using spray adhesive, added it to fill the void.
When the cover is back on, you'll never know it was repaired.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 03-24-2013, 08:43 AM   #6
cdowns
cdowns's Avatar
Re: upholstery??
i have had great luck many times with local upholstery shop/// quite a few times have had real cheap rebuilds for alot less money than the "factory correct" covers alone
Old 03-24-2013, 09:20 AM   #7
Re: upholstery??
$400 is ridiculous for foam. I'm sure you could buy that much unshaped foam for a fraction of that. Petroleum products have gone up,but foam is still mostly air.
Old 03-24-2013, 09:38 AM   #8
chiefcfd
chiefcfd's Avatar
Re: upholstery??
Also remember there are different variations of our seats. Some have full foam bottoms, spring and foam bottoms as well as full foam backs and springs. Could be variable combos. Ask me how I know. I took 3 seats and came up with enough foam and springs to fix my original.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 03-24-2013, 10:22 AM   #9
04 orange
04 orange's Avatar
Re: upholstery??
Thanks guys for the info!! Yeah the seat was pretty toast, but it was free so oh well!! lol. It was a home for some rats for a long time, it even had some tunnels in it that ya cant see in the pic! The foam was absolutely disgusting so I trashed all of it.
Old 03-25-2013, 07:00 AM   #10
bobs409
bobs409's Avatar
Re: upholstery??
Ok, in that case you did the right thing! LOL
If it were me, I'd check some junkyard trucks or do some wanted ads on the net for a good used one.
Bob
