Problem in column, neutral safety switch?
Well I kept wondering about this, and since my steering column has about maybe 1/2" to 3/4" of play in it, I decided to try something. I wondered if when I parked my truck the other day when it would not start, since there is play in the lowerrt f the column, maybe if it's all the way to the left or all the way to the right, maybe that's making a wire or something not have enough contact or something and that's why it wont start sometimes. Thought maybe when I put it in park I pushed hard on it to where it was all the way to the left. So I went outside and got in truck and with my hands turned the column all the way to the right towards the right front tire which like I said is about 1/2 to 3/4 on an inch, and the truck fired right up. Then I turned it all the way to the left towards the drivers side tire and turned the key and nothing at all! I did this like 5 times and every time I had the column towards the left all the way it would not start, only the key turned and nothing at all. So what wire could be causing this in there?
1974 C10 swb 350
1977 3/4 ton Silverado 454
1999 2 door 2wd Tahoe
