Intake spacer question
So I have an aftermarket (Weiand) INTAKE with a spacer on it. The issue I'm having is that the spacer puts my throttle cable at an awkward angle which makes my gas peddle go from nothing to everything in a hurry. This is a problem with my 4 speed manual.
So, do any of you guys know of anyone that makes a bracket to raise the position of the throttle cable? Something that will go around the back of the carb just to lift it a little? Have any of you guys encountered this problem? Here's a pic of my throttle cable - Last edited by Space Monkey; 03-24-2013 at 12:07 AM. |
Re: Intake spacer question
use some longer bolts with flat washers on the bottom
Can you break it down like a fraction for me? Longer bolts where with flat washers on the bottom of what?
I'm sorry, I'm super new at all this and learning as I go. |
The bracket has bolts that mount it too intake remove them and get longer bolts and stack flat washers between bottom of bracket ind intake ............washers serve as a spacer tom raise it up off the intake
Ha! Ok, perfect. I will try that. Thank you sir.
Get the other throttle bracket. Your local parts store should have one.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
In your pic you have the transmission cable bracket and not the upper throttle bracket
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
oh... well that would probably explain it. lol.
I'm with Redcap. Get a bracket. Factory used one that bolted to the carb base. See what the auto parts store has and maybe a trip to the salvage yard.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
#10 | |
http://www.ebay.com/itm/SBC-Q-Jet-th...f39ce8&vxp=mtr heres a pic of mine
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
The qjet one work with my edelbrock?
Posted via Mobile Device |
Fixed. Part right off the shelf at O'reilly's.
Thanks, you guys are awesome. |
