Old 03-24-2013, 12:02 AM   #1
Dan in Pasadena
Dan in Pasadena's Avatar
Task Force - Door WON'T Open/The Other Won't Latch!
So I've been doing a bunch of refurbishing and "things" have been apart awhile.
DRIVER DOOR:
I attached the latch (the on-the-door part) which engages with the long arm to the door handle, then mounted the latch to the door with new screws (yes, the correct ones). The handle movement causes NOTHING to move! I took it all off, manually moved the latch mechanism - it movs fine, the long arm IS attached/engaged on it. I've gotta be doing something wrong.
PASSENGER DOOR
On this door the latch (again, the on-the-door part) had NOT been off the truck. So (I think) I know its installed correctly.
But I removed the part on the door frame (called the striker plate?) painted & reinstalled it, approximately "centered". I did close the door slowly to see if the latch would fit between the "bumps" - for lack of a better term - without hitting them. See "bumps" below:
This is the driver's side. It's right-side-up, isn't it?
It immediately would NOT open, would not "un-latch".
I figured, "It's ok, I left the door locked! I went inside, moved the handle - nothing. Rolled the window down and tried operating the outside button and/or the inside handle and pulled on the door - NOTHING. I tried shouldering the door HARD from the inside - nothing.
At this point I've just gotta figure out how to open the door at all. ALL suggestions deeply appreciated.
Dan in Pasadena is offline   Reply With Quote
Old 03-24-2013, 12:51 AM   #2
Clarance J
Clarance J's Avatar
Re: Task Force - Door WON'T Open/The Other Won't Latch!
Hello Dan. A question first. Are your inner door panels on. Beyond brute force my thoughts were if you had'nt put the panels on yet it might be possible to loosen the door hinges and slide the door forward enough to unjam it. If so be sure the mark the hinges. Reaching the bottom hinge is hard but doable.
You have to have patiences or you'll be one.
Clarance J is offline   Reply With Quote
Old 03-24-2013, 12:58 AM   #3
Dan in Pasadena
Unfortunately, the passenger door panel IS on.
Old 03-24-2013, 01:34 AM   #4
Clarance J
Clarance J's Avatar
This does'nt help you unstick your door but heres a picture of my door drivers side. They do not look the same. Does apart for awhile mean that you had latch plates off of both doors? They could be switched. What can you see looking down where the glass is. Any way to reach latch from that angle?
Old 03-24-2013, 01:53 AM   #5
Dan in Pasadena
Thanks for the photo!
Looks much the same to me. The "bumps" or "stops" are oriented the same as far as I can tell, but its hard to see as my shot wasn't taken straight on as yours is. I'll double check that tomorrow.
Actually, looking down through the window slot is probably my ONLY hope to get the damn door open!
Old 03-24-2013, 02:17 AM   #6
Clarance J
Clarance J's Avatar
Dan, Look at the bottom of each striker plate. The bottom has a slight angle.That is used as a ramp of sorts to push the door up into position when closed and the latch on the door can rotate to the shut position. See if your ramp is going from low out side of door to high toward inside of cab.
Old 03-24-2013, 02:20 AM   #7
Dan in Pasadena
Yes, now I see what you're referring to. I was focused on the upper part as the part that holds the actual latch, not so much the lower part. I'll check and if its opposite yours I'll switch them, IF I can get the door open!
Old 03-24-2013, 09:47 AM   #8
Chevette
Chevette's Avatar
Answer:
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 03-24-2013, 01:26 PM   #9
Clarance J
Clarance J's Avatar
Hello Dan, Hope that when you read this your problem has been solved. If not here are a couple more ideas that you can throw up in the air and see where they land. 1) The screws on the latch look like philips heads. Is there enough lenght on the back side that you might be able to grasp and loosen the screws to loosen the plate and give it some wiggle room. Hopefully at least take some tension off the plate. 2)Back to the door hinge. There are about 13 philips bolts on the door panel. 2 of them you can't reach when the door is shut, but by taking the others out it would flex enough to allow you to reach the door hinge without damage to the panel. Readjusting the door is the tedious part. Heres hoping that you don't need this advice. Stay away crow bars and torches. Good luck.
Old 03-24-2013, 01:27 PM   #10
Rude Dude
Rude Dude's Avatar
Dan don't take this advice in a wrong way buddy, but with camera's in all our cell phone phones now a days I sometimes take a picture of stuff to remind me how it went back together, it sucks getting old right!
Rude Dude is offline   Reply With Quote
Old 03-24-2013, 01:52 PM   #11
Dan in Pasadena
Rudy, I don't take it wrong. You're saying, "You dumb****. You shoulda taken pictures!" And you're right, lol. I KNOW I should have.
Now I'm in a helluva fix. Clarance, no the screw aren't long enough to reach from behind.
I'm in the driveway scratching my head now. More to come!
Old 03-24-2013, 02:10 PM   #12
Dan in Pasadena
Clarance,
Judging from the photo of your strike plate, I have mine on the wrong sides!!!
Which explain why my driver's door won't latch and unfortunately probably explains why the passenger door won't UN latch.
I only see 3 bolts on each hinge. Where are the two others? They're not visible judging from the drivers door.
Old 03-24-2013, 02:15 PM   #13
mr48chev
mr48chev's Avatar
Over the past 40 years of messing with old trucks I've found that the first thing a guy needs to do is properly align the doors with no latches on them and then install the latches. That saves a lot of fighting with stuck latches.
My ongoing truck projects:
Old 03-24-2013, 02:38 PM   #14
Dan in Pasadena
Ok, I got it open you guys! HALLELUJAH!!!
Basically it was wedged tight. Nothing was holding it really. Can't figure that because I didn't slam it closed. Anyway, my Streamlight flashlight, a long screwdriver and a single rap popped it open. Now to swap the striker plates!
Old 03-24-2013, 02:42 PM   #15
Clarance J
Clarance J's Avatar
Hello Dan. On these door hinges there are 6 bolts on each hinge upper and lower. 3 on the door and 3 on the cab mount. Top and bottom. The bolts I am talking about are in the door only. They mainly adjust the door front to back. The cab hinge mostly but not limited to is for body alignment and up and down. I think the only way to get your door to move is through the hinges. Be sure not to scratch the paint.
Old 03-24-2013, 02:48 PM   #16
Clarance J
Clarance J's Avatar
YAHOO. Glad you didn't have to go through all the trouble.
Earl aka Clarance J
Old 03-24-2013, 02:49 PM   #17
_Ogre
_Ogre's Avatar
mr48: i read that and thought to myself, boy that guy must be old and then realized i bought my 1st 58 in 1972. 41 yrs ago
dan: a couple things.
your striker plate looks wrong, universal fit for both sides. everyone i've seen has been like what clarence posted 2 pieces riveted together.
the door that is latched... if it's all the way closed, push hard and then unlatch it and pull hard. sometimes they latch hard when in a bind.
shop air compressor timer
Old 03-24-2013, 02:51 PM   #18
_Ogre
_Ogre's Avatar
dang i type slow
glad you got it.
Old 03-24-2013, 05:04 PM   #19
mr48chev
mr48chev's Avatar
I'm only 66 Ogre but I hung around the "older guys" with cars a lot when I was real young.
How are you coming on getting that door open Dan?
Old 03-24-2013, 05:16 PM   #20
Highsider
Highsider's Avatar
Scroll up a few post and I gather he figured it out.
Highsider is offline   Reply With Quote
Old 03-24-2013, 05:54 PM   #21
mr48chev
mr48chev's Avatar
Well paint my face red on that one. I forgot rule 1. and that is to read the whole thread before answering. Rule 2. is to read the dates of the previous last posts before posting.
Good to see that someone is accomplishing something. Now back out to the work area to hunt for some metric bolts for the box with wheels that seemed to have grown feet.
Old 03-24-2013, 05:59 PM   #22
Highsider
Highsider's Avatar
I like "Rule 1 & 2"....
I am borrowing for other forums I am on.
Old 03-24-2013, 08:46 PM   #23
Dan in Pasadena
On my iPhone the photos I post show upside down but everyone else's are right side up! No wonder my striker plate doesn't "look quite right".
Anyway, got a lot of my Mickey Mouse painting done today and I'm bushed. I'll post some photos later
Old 03-25-2013, 12:01 AM   #24
1project2many
Ogre, in my experience 55-57 trucks had a one piece, cast striker where 58-59 trucks used the two piece style. Now maybe this isn't completely true but I know I've pulled far more one piece strikers off trucks in the 55-57 range than two piece. My 57 has one piece strikers as well.
The door striker adjustment can be tricky. An old timer once told me the striker is supposed to put some downward pressure on the door and latch so I've always followed that advice during adjustment.
1project2many is offline   Reply With Quote
Old 03-25-2013, 01:08 AM   #25
Dan in Pasadena
Yup, my striker plate is one piece.
I put the driver's side striker plate on; eye-balled at mid point and it latched first time. It also releases just fine.
I did the same thing he passenger door and it doesn't latch yet. I ran outta time to play with it but I'm sure it's just the adjustment. I'll play with it more tomorrow.
I'm THIS CLOSE to being able to mounting the door weather stripping. Yes, I've done a search and I know it doesn't go on like it would seem to. It doesn't contour to the door inner lip, it goes on opposite that - per my search results.
