Got a problem
Ok guys, I've got a problem with my truck. Every once in a while I go out to start it and drive but it won't start. Everything else works on the truck, radio, gauges move up, etc. But it won't even try. GrandPa said it could be a wire with the starter, so I jiggled the wire and still nothing. I mean it won't even try to turn over, my stepdad and his friends couldn't find out what it was. But then a hour later I go out and it starts... Any of you guys know what's goin on? It will start then 2-3 hours later it won't then it will. I don't understand it. Like it goes when it wants to lol. Thanks
Posted via Mobile Device |
Re: Got a problem
Is it an automatic? If it is jiggle the shifter, it could be the neutral safety switch.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Re: Got a problem
Yea its auto and I did. But the thing is my truck will start in any gear? Ha idk why guess the po did something wrong. But yes I did try it and nothing. Doesn't even try.
Re: Got a problem
It starts in any gear ?then I would say neutral safety switch finally shorted out .
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
Re: Got a problem
Yea I guess. I just don't understand why it starts now then later it doesn't. I just don't wanna be at school and have to get to work then it won't start. And have to sit there till she wants to go.
Divorced .....WITH KIDS
Re: Got a problem
My truck occasionally does the same thing and I can't figure it out . Has new wiring harness , starter etc but I never thought about neutral safety switch .
1969 GMC SWB 1975 Chevy Malibu 80k 1963 Ford Galaxie 63k (inherited) 2005 Nissan Armada (wife's idea) |
Junior Member
Re: Got a problem
My '92 GMC was doing the same thing. If hit the solenoid with some thing it would start, I finally got tired of doing that and replaced the starter.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Re: Got a problem
You could probably just start it with a pliers on the solenoid. That would implicate any ignition wires in the cab. Don't try that unless you've done it before... best to find someone with experience when resorting to jumping stuff. lol
Dane 67 Chevy Fleet 250/4 speed 1/2 ton 68 Chevy 250/4 speed 1/2 ton for parts 49 GMC Grain truck 235 1 1/2 ton 76 Chevy 350/4 speed 1/2 ton |
