Help with identifing piece.
When in doubt, ask you all. I took a picture of something that id attached to the radiator support behind the driver side head lights. It has two or 3 plugs that are not plugged in, including what looks like a temp sensor. Can you tell me what it is and if I need it. It was already there when I bought the truck and never messed with it. I am cleaning up under the hood and don't know what to do with it.
thanks |
![]() Join Date: Oct 2010
Re: Help with identifing piece.
Just guessing but maybe part of an electric fan setup.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
Old member
Either stated above as in relay for the electric fan are for the head light upgrade. Not really sure. Can you trace out the wires and see where they go?
To me it looks like they started something then left it alone. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
It looks like a 60amp relay switch. Prob attaches to headlights and electric fan.
Sounds right. Thanks guys. I will run down the wires.
