what size and make rims/tires?
ran across this truck pic..wondering what kind(stock? aftermarket?) and size rims and tires and bolt pattern?.....will these also work on a 1998 GMC(5 lug)?...any trouble with backspacing?..any other mods that might be needed..I take it this truck has a cross member swap or 5 lug conversion..I like this look and am curious if these would be available in the local boneyards..
67-72 parts collector,
![]() Join Date: Nov 2002
Re: what size and make rims/tires?
Those are dodge 20" steel wheels. (spares)
They are the wrong bolt pattern. (5x5.5) Your truck has a 5x5 pattern.
Thanks..might there be a steel rally type rim bigger than the stock 15"(16,17,18) that would work?
i used this database to find wheels from other vehicle that might fit out trucks (provided you know the bolt pattern you are looking for)
http://www.roadkillcustoms.com/hot-r...e-Database.asp updated link. should work now |
I thought those were off a newer Toyota fj cruiser.
They have the correct bolt pattern if they are. Steven
Life is and will ever remain an equation incapable of solution, but it contains certain known factors. - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life? http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
Toyota FJ (spare) wheels are 17" and 6-lug.
Oh yeah, now I see. Sorry.
I want those! Steven
thanks for the chart and info..will look for the 17" Toyotas to fit my '64 w/6 lugs..so I could use the 20" Chrysler rims w/ wheel adaptors...
