Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-24-2013, 02:44 PM   #1
skeeterbug
skeeterbug's Avatar
trailing arm axle perches..where to get?
I will be fitting the refurbished/narrowed ford 9" unit under my truck hopefully this week. When I talked with the guy at Moser Friday he said it would be back on the truck coming my way in two working days. Anyways where have you guys been getting replacement axle perches for trailing arm susp., I found some through cpp but damn that $45.00 plus freight! I will not pay that much for a piece of steel that's made in china or somewhere for .50 cent. There has to be a better option?
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 03-24-2013, 03:21 PM   #2
bigboybodry
bigboybodry's Avatar
Re: trailing arm axle perches..where to get?
check with classic performance parts they have them.
6072RAS Weld-on axle seats for 3 Inch diameter axles $39.00
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 03-24-2013, 03:36 PM   #3
moggey01
What size axle tubes do you have? I have a set from speedway engineering that where fit for a bigger tube.
moggey01 is offline   Reply With Quote
Old 03-24-2013, 07:05 PM   #4
skeeterbug
skeeterbug's Avatar
3.125
2013 best 7.39
2014 best-7.38
Old 03-26-2013, 03:32 AM   #5
moggey01
The set I have was fit for a 3.5" tube.
Old 03-26-2013, 08:32 AM   #6
vin63
It's Better With Nitro
vin63's Avatar
I usually purchase them through Early Classics: Part # 02-8005 - $39.
http://earlyclassic.com/catalog.aspx
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-28-2013, 12:17 AM   #7
Captainfab
60-66 Nut
Trailing arm mounts for $39.00 is a good deal. Mine are much more than that. I can't make them any cheaper than what I sell them for.
Old 04-04-2013, 05:24 PM   #8
funnyfarmracer
Hot Rods to Hell in california.
funnyfarmracer is offline   Reply With Quote
