Rear View Mirror
Ive seen a ton of post about 72 rear view mirrors glued to the windshield. But my 72 has the mirror mounted to the roof at the top of the windshield and the metal looks like it was made to be mounted there? Anyone know what up with this? Thanks
![]() Join Date: Oct 2010
Re: Rear View Mirror
That's not the inside of a '72 cab. Could it have been changed by the PO?
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
It hasnt been changed...
I dont know what differences there is in the cabs. I can take a picture of anything in the cab and post on here for you to check if theres a difference in it than a 72. I would really like to know whats up with the cab.
member #16
![]() Join Date: Dec 1999
71's were the only year with the mirror mount like yours. Posssibly built at yr. model change.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
That is the 71 only style. What plant and serial number do you have? Is the blue door sticker intact? Are the data plate rivets original?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
I'm guessing it was built at year change. This is what they are talking about with the diffrence
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
72 GMC super custom. ![]() |
This is one way to know if you have a 72 unless they changed the doors lol Posted via Mobile Device Posted via Mobile Device
The passenger door is like that but drivers isnt. The plates are all in tact and the numbers match everywhere. I was planning on changing drivers door to a actual 72 but that's a different story.
Posted via Mobile Device |
Yup
I'm guessing. Just built furring the change. They used what they could Posted via Mobile Device
If it is because of the end of year change, isn't that falsely advertising it to be a real 72? I would call GM and demand they replace it with a new 72 truck they got stashed somewhere!!
![]() Posted via Mobile Device Posted via Mobile Device
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
My 72 had the mirror mounted on the cab as well. I removed it and went with a mirror mount instead.
#13 | |
#14 |
Well the mount is there so I would say its original
#15 |
If u moved it the mount on the roof would look odd. IMHO
#16 |
The drivers door is different from the passenger but yet under the red it's the factory blue as everything else on the truck.
#17 |
Hmmm same # s too?
#18 |
What do you mean by same numbers? Sorry...
#19 |
On the doors and such they all match?
#20 |
Where would they be on the doors. I'll go check now
#21 |
Could b wrong I think there are numbers along the edge somewhere not sure bout doors just odd one is 72 while the other isn't
#22 |
The driver's door should have a blue sticker with the VIN and build month/year. The driver lock pillar should have a metal plate with the VIN and rivets with scalloped heads. The glove box door should have a SPID with both a VIN and a model number. These VIN numbers should match your title and both the frame number locations. The reason I wanted the numbers (serial and plant) in addition to the build month/year is to see how this matches up with other trucks. I track variations.
#23 |
^ awsome thanks now I know too
#24 |
Couldn't find any numbers. Although it's pitch black here. Might have missed them. I'm gonna take off some paint on my drivers door tomorrow and make sure its blue under it other places. Probably gonna start the patina look tomorrow.
![]() Posted via Mobile Device |
#25 |
Ss Tim. Thanks for the info I'm gonna check all numbers tomorrow when I get back from school. Scott thanks for the help tonight. It's gettin late here so it's about that time. Again thanks guys, mystery shall be solved tomorrow after school.
