Old 03-24-2013, 07:33 PM   #1
Mark3100
Mark3100's Avatar
350 V8 fitment in 49 C3100
I,m currentlu placing a 350 in a 49 C3100 and it appears that if I give enough room to clear the distributor (Pertronix HEI) the radiator will not fit. I would rather use the thermal clutch but will use electric if I must. I guess I could cut the large firewall recess and make it deeper. I have seen so many 350's in these trucks and just wanted to get some help before I start cutting. Just for reference, my harmonic balancer is just above the old front engine mount holes and I have a long water pump. Any pictures would really help!
Thanks!
Mark3100 is offline   Reply With Quote
Old 03-24-2013, 10:16 PM   #2
G&R's57GMC
G&R's57GMC's Avatar
Re: 350 V8 fitment in 49 C3100
You might want to use Speedway's High Rise water pump it will center the fan and may shorten the overall length of the engine.
G&R's57GMC is offline   Reply With Quote
Old 03-25-2013, 04:19 PM   #3
Katrina/10
Katrina/10's Avatar
There should be plenty of room for a radiator and distributor with a stock firewall, but not an clutch fan. I ran a straight fan for a while, but a lot of the blade is below the radiator. I ended up using an electric fan due to low speed cooling problems.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
