Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 03-24-2013, 08:07 PM   #1
LT1 Burb
LT1 Burb's Avatar
WTB AC Pulleys including wp
I am at my wits end. If anyone has a complete set of pulleys for a 65-66 that are on a motor or were all on the same motor I am looking for a set. Must be factory air with power steering and be the whole set and they must line up. I have tried every combination of everything I have and can't make mine work.
LT1 Burb is offline   Reply With Quote
Old 03-24-2013, 08:48 PM   #2
sigshooter
sigshooter's Avatar
Re: WTB AC Pulleys including wp
The water pump pulleys are the hardest to find ( A/C only ) the crank pulleys are the same with just power steering.... I have a set on an engine I can take pictures of for you if that helps any.... The engine is one I built 20 years ago and have never put it in the truck yet, still on the engine stand... truck is sitting under a shed waiting to be built
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 03-24-2013, 08:51 PM   #3
contagious102
contagious102's Avatar
What engine?
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline   Reply With Quote
Old 03-24-2013, 09:01 PM   #4
LT1 Burb
LT1 Burb's Avatar
I can't get my pulleys to line up, I have the cast iron 3 belt water pump pulley and 2 sets of crank pulleys but nothing works. Let me see what your setup is, maybe it'll help, thanks.
Old 03-26-2013, 09:52 AM   #5
LT1 Burb
LT1 Burb's Avatar
Its a 283, I have one coming off of ebay and its the more common 2 piece water pump one. Lets see if that works , if it doesn't I am throwing a hissy fit.
Old 03-26-2013, 01:31 PM   #6
HOTFUN
HOTFUN's Avatar
I was planning of using the original 2 piece steel pullies but adding the fan clutch onto it since the GM dealer ac kit version must have not came with the cast water pump pulley and fan clutch. On the same thought I wonder if that's why GM changed production of that heavy long cast pulley to the lighter steel pulley on the factory air vehicles after 1967 because of water pump failures? You hang that cast pulley and the fan clutch and HD fan out on the end of that standard water pump and you have a lot of bearing load on that water pump. If your eBay purchased double steel pulley 65-67 ac accessory style doesn't work then maybe going to the 68-72 style a/c short water pump steel pulley might work?
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
